Question about Intel Motherboard
Motherboard where can we locate the brand, model, capacity etch.of the motherboard?can we locate it in the motherboard?
  • LMHarris Apr 24, 2009
    where on the mortherboard would i find the make on number of it????
    Scholar:
  • 89 Answers
Hello, yes, The Model number is located on the motherboard itself. It is sometimes hard to see. After you find it you can google the number and ususally get all info. You also can possibly find a Manufacture web site and also get specs. Hope this helps, good luck..!!
Posted on Mar 28, 2008
INTEL DRIVERS D915GAG VERSION:EV91510A,86A SIZE:512KB
Posted on Apr 25, 2009
Why is it important to know different beeps when dealing with computers?
Beep codes come from a piezo speaker on your motherboard and identify problems with the power or configuration of the motherboard.
Different motherboard manufacturers use different beep codes, so Googling the words "beep codes" along with the model number of the motherboard (an etching on the board itself) will usually locate your results.
In any case, go to the website of the motherboard manufacturer to find the information, ususally in support or downloads to find the manual for your specific motherboard.
Most common beep codes:
  • . Missing keyboard
  • Can't find CPU
  • RAM missing, improperly installed or failing
Sep 25, 2017 | Computers & Internet
Cmos battery location and size
The battery is located on the motherboard, and looks like a watch battery. Its type is etched on it.
Nov 07, 2011 | HEWLETT-PACKARD Compaq Presario SR2017CL...
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
Hi sir i have formated my computer and i dont have the drivers cd for it please let me know where can i get the drivers for m903lr motherboard
I have to know either your computer's brand / model (in case of a branded one) or your motherboard's brand / model (in case of a custom made). You can locate the motherboard's brand / model near the VGA slot at the center of the board.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 07, 2011 | Computers & Internet
What is the max hardrive for a dell precision 340
Hi!
As of our current technology ALL Motherboard can support the most biggest hdd capacity which is 2TB (Terrabyte). You can even use a 10 TB single hdd on your motherboard if you have one.
Regardless of brand and model it will still be the same.
Cheers~
Sep 10, 2010 | Dell Precision 340 PC Desktop
Too much memory for Giga-Byte K8M800-8237
The issue of this is not too much capacity on your memory., i tell you the problem is incompatible both of them. Check again your memory and what brand are there.
Because something motherboard settings are being notify if reliable to you to use different kind of RAM you have. Read the motherboard manual to find out some settings to enable both of them are not the same brand or model.
Aug 03, 2009 | Gigabyte GA-K8VM800M Motherboard
What controls memory capacity?
The maximum amount any computer will work on is 4 gigabytes. You may see some specialty models with 6GB but that is a waste of money because programmers write programs for a maximum of 4GB as that is the industry standard. The maximum memory capacity depends on the motherboard setup. For instance, any desktop can take up to 4 GB but some smaller laptops cannot. It depends on the company selling the product as they decide which motherboard to install. Netbooks, 7" to 10" screen can only hold 2 GB, while all 15" and above laptops can hold 4 GB. So basically 4GB max or less. Obviously 4GB will run faster than anything less. Memory is fairly cheap so always go with the 4GB. Second part of your question,manufacturers decide which motherboards go into which computers and the larger dealers like Dell, HP, Compaq, etc will always offer 4 GB. Inexpensive computers like Emachine cut cost by not spending the money for the best motherboards so they may only hold 2GB. Hope this answers your questions.
Don't forget to rate this solution before logging out.
Jan 23, 2009 | Dell Inspiron 2650 Notebook
How find motherboard drivers, chip usb sound diplay
please tell what kind of motherboard?
is the motherboard already installed in a computer?
look on the motherboard, possibly on the back, there should be a etched label in green identifying the board make/model.
if the board is already installed and you can get the system to boot and get into windows, then go get BELARC (Belarc.com) and run that. It ill tell you everything you need to know. Won't give you links to products, but you can print it out and begin your search.
MOST motherboard MFR's have websites and have all the drivers available. ALSO, if it's a NAME BRAND (Dell, HP, etc) then you can go to support.HP.com and begin the task of looking up the system.
If you need more help, contact me through this website.
Jan 15, 2009 | Computers & Internet
HOW TO CHECK ASROCK MOTHERBOARD WARRENTY
»For Authorized Distributors Only: (Email: rma@asrockamerica.com)
»End users or indirect customer:
Thank you for choosing ASRock Motherboard. Due to the unique configuration of each computer, we recommend you to contact your dealer for technical support. If you would like contact us for technical support. Please send us an email support@asrockamerica.comand give us a detail discription of the problem alone with the following information.
  • CPU/Processor (Brand,Speed, FSB,Cache Size)
  • Memory (Speed, Capacity, Brand)
  • Video Card (Brand, Model, Memory size)
  • Operating System (Loaded service pack and driver)
  • Hard Drive (Brand, Model, Capacity)
  • Other Device (Brand, Model) * If necessary
*Additional system configuration information may require.
ASRock provide 1 year warranty service to Authorized Distrubitor ONLY, users should refer to the retailer or original vender RMA & Refund policy. For non Direct Customers, there is a $35.00 service charge + shipping for each item.
BIOS $15.00 + shipping
ASRock CD $5.00 + shipping
ASRock I/O Panel $5.00 + shipping
»ASRock Service Center (Brasil)
R: Andre Ampere, 153 -17 andar - SI173
Brookin Novo - Cep 0462-080
Tel/Fax: 55 11 5105-3137RMA Service: Email: rmabr@asrockamerica.com
http://www.asrock.com/support/index.asp?c=RMA
Dec 31, 2008 | Asrock 775i65G Motherboard
Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Feb 07, 2008 | Heating & Cooling
Intel Motherboard Logo
159 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
