Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
I have a troy bilt tiller with a 2hp motor.lately i have had to run it with the choke on and then when i engage the tines it will go dead.have any ideas thanks the engine is a tecumseh
    President:
  • 957 Answers
You can check the linkage that links the governor to the carb. If that is fine then you can check the fuel line for a blockage, the carburetor for debris, and if that is fine then you may want to try sanding the rust off the magnet (on the fly-wheel).
Posted on May 10, 2010
Engine runs on half choke
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Sep 07, 2012 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Choke is not hooked up to anything. What does the choke hook up to on a troy built tiller?
The choke (butterfly valve inside the carburetor) is attached to a lever on the side of the carburetor. This lever opens and closes the butterfly valve. Attach the choke cable to this lever.
Apr 29, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt tiller dies when I engage the tines.
Bogging down may indicate debris or old gas in the carb. Try doing a carb cleaning, and add a small amount of Seafoam gas additive to your gas.
Mar 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
249 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
