Question about HP PSC 1350 All-In-One Thermal Printer
Printer does not print. The paper does not get sucked in to print and complains about out of paper even though there is enough paper
    Novelist:
  • 142 Answers
Please perform the steps provided in teh following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=uk&lc=en&dlc=en&product=306888
Now verify the result.
:) Dr Tony
Posted on May 10, 2010
My kodak esp 5210 will not print a test page or a document from my computer.
You will only get the calibration page no matter what you try because the printer needs to complete that task before it will let anything else get printed. This cannot be avoided for this model printer! Just follow the instructions as listed on the calibration page (even though you think it may not be needed) and then the printer will act normally!
Good Luck!
Rich Lilja.
Feb 27, 2015 | Kodak Esp 5210 All-in-one Inkjet Printer
What do I do when my printer is sure there is still a paper jam when I already cleared it?
There is a small plastic switch, really tiny and light, so light that a small bit of paper can depress it. This detects the presence of paper in the paper run. If it is stuck down, probably by a sliver of paper torn off when clearing a jam it can cause the printer to do as you have described.
Jul 20, 2014 | Canon PIXMA MP160 All-In-One InkJet...
My 842C Deskjet had a paper jam and even though I pulled out the paper, The bottom red light continues to flash.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 19, 2009 | HP Office Equipment & Supplies
Error message says"out of paper" when paper tray is fully loaded
check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
The printer says it is out of paper, even though it is loaded
clean your paper rollers in side printer and make sure spring on paper loader isn't sprung
Jul 27, 2009 | Dell Inkjet 720 Printer
My printer do not print any file
I usually face the following problem while giving printing command to my printer:\r\n
1. On clicking print from file meno the printer does not print and the yellow light upwards starts blinking.
2. Reinstalled the printer after inserted the Printer Software *C6464-10018* v 41 *MacOS 8.1*USB
but printing did not start from this even.
3. sometimes earlier I experienced that only 2-3 lines get printed and after that the upper yellow light again started blinking.
4.Some times the printer goes on sucking papers and prints as the signs of playing cards or some other abnormal shapes lining etc.
Please be kind enough to solve my all such problem and if possible point out step by step action to be taken by me during such an eventuality at a later stage also.
regards: rcsharda44@yahoo.in
Jun 12, 2009 | HP DeskJet 640c InkJet Printer
Problems with the paper feed.
I had this same problem with my HP 2575 printer. I complained very strongly to HP and they sent me (free of any charges) an HP Paper Cleaning Kit. Took about 20 minutes to clean and rough up a rubber feeding roll in the printer. VOILA-- printer has been feeding perfectly for over a year. A friend of mine with the same printer,had the same problem. He used it and now has no problem. You will have to get after HP and have them send you the Kit. Hope this helps you out. SANS
Nov 20, 2008 | HP Photosmart C5280 Printer
No paper fed
I'm guessing that little piece of plastic has something to do with the paper sensor.  You may want to open that section and set it back the way it was.
Oct 27, 2007 | Brother Multi-Function Center MFC-240C...
HP PSC 1350 All-In-One Thermal Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
