Question about Sharp Televison & Video
After dusting my tv, now the remotes will not operate tv set. have little green leaves that pop up at bottom of screen with opc. cant get into menu to make any changes to setting.
  • cterry401 May 10, 2010
    I cant beleive that was the only thing i didnt try. its working.
  • 11,896 Answers
Make sure or try cleaning the optical sensor on the tv where the remote responds to.
Posted on May 10, 2010
  • Nate Stansfield
    Nate Stansfield May 10, 2010
    Awesome! Glad it works now!
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
I cant get the menu to leave the screen. I dont know what button to push.
Hitting the menu button again will clear this off most of the time. Make sure you are using the correct remote. If it is the cable menu use the remote that came with the cable box. If it is the tv menu uses the original television remote control. This can also be taken care of with the buttons on the television itself. Should be a menu button on the side or bottom.
Apr 02, 2014 | Dynex Televison & Video
Is it normal for opc and the green leaves to flash across my screen on my sharp tv?
You can turn this feature of in you menu. It is adjusting to change in roomlighting when you see this come on. Look in your menu for OPC on off setting under features menu.
Jul 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
My 2 yr old grand daughter had the remote the other night and pushed something on the remote ; so all I have now is a black screen and audio. The OPC Indicator is on and green. The manual doesn't help at...
Several things to consider/look at.
Go into the main menu and look at the Back light and Brightness settings. They may have been turned down.
Go into the main menu. Click on to the Picture section. Click on ^ v to select OPC.
• For resetting all adjustment items to factory preset values,
press ^ v to select "Reset", press ENTER, press to select "Yes", and then press ENTER.
Unplug the set for several hours to let it reset
Remove remote from 2 year old.
Mar 10, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
What is opc that pops up about every 10 Min
OPC is optical picture control. The television is adjusting itself to the lighting in the room. Even if someone walks in front of the television's sensor it will start to adjust and you will see opc on the screen and green leaves.
You can leave the feature on without the opc and green leaves appearing on the screen. Press the menu button. Scroll down to OPC. Press enter. Scroll to on. Press enter. Press menu to exit.
Sep 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My hitachi 960 tv has a green screen
you should take the remote,press the menu key.select the screen settings.in this you can set your screen.
Jan 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
NEED TO GET GREEN MENU ON
You some how got into the service menu, and your going to need to call an authorized servicer for this brand, and they are going to have to tell you how to put the TV back to factory defaults, If thats not possible, the sets going to have to be re adjusted and go through every alighnment to see what you changed. If that ever happens again, cancel out of that menu, as its for the trained tech to change things, as theres a process that has to be followed.
Sep 16, 2006 | Bush 1433GRN2 14" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
