Question about Garden
I have a new proline pool pump that i just installed with my new pool. when I plug it in it runs for a minute or two then stops. it will restart after 5-10 minutes. I tested the plug and got 240 volts. I have checked for obstructions in the lines etc. I was hopeing this is something i can easly fix myself as uts an hour + to the place I bought it. I have not changed any of the wireing on the pump.
  • 4,070 Answers
It sounds like the pump is overheating and shutting off to protect it. Is it pumping water during the minute or two it runs.? The water usually helps cool it when it's running. Since it's a new pump I would suspect a defective pump. Check warranty coverage.
Posted on May 10, 2010
Pump motor not operating
The pump is defective and will need to be repalced.
May 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
My pump will stop and restart a few minutes later during its programmed run time, during warm and cold weather, the pool water is in the 50's.
With these pool pumps, it is probably either that you are getting air pockets or leaks in the suction line or your pump strainer is clogged.
Mar 01, 2010 | Pentair Wf 6 1.5hp Whisperflo Inground...
Polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
