Question about Maytag Atlantis MDG7400AW Gas Dryer
No Heat My dryer just stopped producing heat any suggestions to the issue
    President:
  • 1,382 Answers
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you!
Posted on May 10, 2010
Dryer is not producing heat
Good Morning friend, thanks for your inquiry!
I understand that your Frigidaire dryer is not producing heat. Have you checked the exhaust vent to assure there is not a build-up of lint blocking ventilation? If so clean out the lint and check to see if your appliance heats after that. It could also be a potential issue with your element or thermostat I would suggest seeking assistance from a technician for further diagnose. I hope this information helps. -Matt
Sep 28, 2014 | Frigidaire Dryers
Frigidaire dryer doesn't produce heat, but everything else is working. What do I do to fix that problem?
Unplug remove panels necessary
Check the element for breaks or issues
if no problems found replace the safety devices directly in line with the power supply for the element
Nov 15, 2011 | Dryers
Not producing much heat---takes 3-4 hours to dry a load of towels---gas is working as I can hear it
check for blocked vent tube issues,, if the machine can't vent correctly it goes on then shuts down with the heat over and over again Until its just gonna stop. If thats not the problem check out this blog by Heatman http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
May 25, 2011 | LG DLG5988 Gas Dryer
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Feb 18, 2011 | Dryers
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
The dryer unit I have has stopped producing heat
could be either the ignitor or a bad coil on the gas valve or a bad gas valve to start with..
Jul 21, 2010 | Kenmore Dryers
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
GE Electric dryer doesn't produce any heat. Before the heat totally went out, it would not self-regulate itself to stop producing heat. We would need to turn it off manually. Can you please tell us what...
I do not know the cost of repairs, but it sounds like your thermostats, and or the timer switch is faulty.
You will need to contact an appliance repair man in your area to determine the cost of repair.
I hope this helps
Oct 04, 2009 | GE Dryers
My dryer is not producing heat. Just cool air!
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 17, 2009 | Dryers
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
138 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
