Question about HP (D7580-60003) Motherboard
YANG AN YA-1 E114139 94V-0
How do you clear the cmos pass word on this board
  • 1 more comment
  • sacr_face217 Apr 03, 2008
    Down in the corner where you connect speaker,hd-led,reset pins just above that are two plugin chips. The smaller is the one you pull while power is off reset in backwards repower, then power down reverse the chip in the right way and Cmos will be reset
    posting for
  • dan sweeney Mar 06, 2009
    Accidently in a rush put the edge connector on reverse. Wish the board had a key to avoid that but my fault. Look like it blew a hole in the ULN2003A chip near the connector. Is it likely the board is trash or can it be repaired?
  • joalke Apr 30, 2009
    Hi. Anybody have a manual for this MoBo?
    I need info about how to connect the reset-switch cable.
    Also the HD-Led, Power-led, Speaker and so on.
I want drivers for the motherboard: YANG AN YA-1 E114139 94V-0
Posted on Jan 23, 2009
    Genius:
  • 1,027 Answers
If you don't see a jumper near the button cell battery that has written cmos clear, than pull power cord out, remove button cell, press power button to disipate any stray voltage, re-install button cell, plug power cord in boot up, cmos checksum error will appear, enter bios setup utility, re set time date etc, save and exit. boot up.
Posted on Mar 28, 2008
SOURCE:
Bios password lenovo T60
there are 2 ways to attempt it. 1/ you need the diagram of your mother board as it involves changing a jumper setting on the board to clear the pass. 2/there is a small round battery inside ( could be under a cover under the laptop ) unplug that battery for a while to clear the cmos. hope this helps
May 01, 2015 | IBM Lenovo ThinkPad T60
Pasword bola88 saya ada yang merubah.bagaimana caranya menemukannya ya...tlg dong...
paspowrd dan nama bola 88 saya ada yang rubah ...
gmn boss buat log inn lagi dan bermain disitus ini...
Nov 28, 2013 | google.com
SAYA PUNYA MASALAH DENGAN MOTHERBOARD ASUS P45533-MX SY,DI TEKAN TOMBOL POWER KIPAS PROSESOR TIDAK NYALA TAPI LAMPU LED CONROL DEKAT SLOT PCI NYALA.TRIMAKASIH MOHON BANTUANNYA
hallo sujanajohan, coba cek kabel kipas processor apakah sudah tersambung ke motherboard atau belum? jika sudah berarti ada dua kemungkinan: 1. power supply yang anda gunakan kekurangan daya (Watt) 2. kipas processor anda sudah rusak.
jika kipas procesor anda terbilang masih baru maka kemungkinan besar power supply anda yang bermasalah. karena lampu LED motherboard hidup berarti power supply anda tidak rusak, maka kemungkinan terbesar dari masalah anda adalah daya power supply anda kurang besar
NB: jika anda membeli power supply yang harganya hanya sekitar 100ribuan walaupun Watt-nya besar seperti 450W, tetapi sebenarnya itu bukan 'truepower' sehingga daya yang dihasilkan tidak sebesar yang tertera di kardus, belilah power supply yang memiliki true power, harganya memang mahal, tetapi sebuah power supply yang memiliki true power berdaya 380W lebih baik daripada power supply 450W yang tidak memiliki true power, dan tegangannya stabil tidak merusak komponen komputer yang lain
semoga ini membantu.
Aug 23, 2011 | ASUS P4S533-MX Motherboard
I dont remember the password bios HP pavilion zd8000
Two ways to reset the Bios/CMOS password are as follows: Basically option number is recommended. 1. Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults. You can do this by removing the CMOS battery from *********** board or by resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper)
2. By using a program to either locate and identify the password. This programs are referred to as password by-pass utilities or cracks.
Mar 18, 2011 | HP Pavilion zd8000 Notebook
I have a motherboard from a Vicon Kollector CCTV DVR that has failed. The only markings I see on the m/b are yang an ya-3a e114139 94v-0. I am trying to find a replacement since the board is obsolete...
The only motherboard I find with those ID numbers is this puppy,
http://cgi.ebay.com/HP-MOTHERBOARD-YANG-YA-3-94V-0-E114139-W-DUAL-CPU-/300439081565?pt=LH_DefaultDomain_0&hash=item45f390925d
Or this one,
http://cgi.ebay.com/YANG-YA-3-94V-0-E114139-DUAL-SOCKET-370-MOTHERBOARD-/310198934835?pt=Motherboards&hash=item48394c1d33
If this is the mobo in question it's probably one, or more of the Voltage Regulator Modules has gone bad.
(Voltage Regulator for the Processor. Two Processors, two Voltage Regulators)
Or perhaps one, or more of the Electrolytic Capacitors have gone bad.
http://www.capacitorlab.com/visible-failures/
A competent computer repair shop could replace them.
(We are getting less, and less)
Oct 20, 2010 | HP (D7580-60003) Motherboard
Need picture of yang an ya E114139 94V motherboard
The ECS RC410-M motherboard? HP name Asterope3-GL8E?
(D7580-60003)
This link to HP.com/Support, shows where the CMOS jumpers should be, http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00783614&lc=en&dlc=en&cc=us&lang=en&product=3262274
(Scroll down to towards the bottom of the page)
Jan 19, 2009 | HP (D7580-60003) Motherboard
YANG AN YA-1 E114139 94V-0.
The E114139 94Version 0 is an ABIT KD7 non-raid board
This link will allow you to download the manual, I would suggest the http site for download as some times the recommended site has errors.
Mar 30, 2008 | HP (D7580-60003) Motherboard
Electronic engineer
how to disable onboard vga?
Sep 23, 2007 | HP (D7580-60003) Motherboard
HP (D7580-60003) Motherboard Logo
6,922 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
