Question about Apple PowerBook G4 Mac Notebook
No image - only the back light is on. No desktop display
No image
    Guru:
  • 1,481 Answers
If it's new then get it replaced...
else u need to get it fixed from a tech shop....one of the below is @ fault....
1 the LCD screen is gone,
2 the backlite (a small tubelite) is gone
3 the invertor board(a small PCB) behind is gone
Posted on May 10, 2010
Lenovo 3000 n100 lcd display works but only less than a minute before display goes black. Connect an external monitor and it works fine.
possible problem is your led light on your LCD or its Flex. you might need to have it replaced. Try to check your LCD when it turns black under the light if you can see a dark image of your desktop. If you can see your desktop then the backlight has a problem. If there is no display, your LCD needs to be replaced.
Aug 13, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
In my computer my desktop image is not displaying while i boot it
you should have been attacked by virus problem...and you have installed a pirated version of windows i suppose..install an original antivirus software, get your desktop cleaned..this is will be a good solution..feed back pls
May 22, 2009 | Dell Dimension 2400 PC Desktop
No display image.only back light.
Friend, as a mobile techncian for how many years. I encountered many of such problem. Your problem is the lcd connector at the back of the LCD display. a small slot having small pins is detached thats why it cannot display. It is need to be resolder.using a electronic soldering iron. But be careful not to short the pins of the connector. Good luck.
Apr 23, 2009 | Nokia 6070 Cellular Phone
Have Evesham "Blue Beast" c/w Epson R300 printer etc. Have been trying to download images from sd card into p.c. Card reader light glimmers when inserted, but no dialogue box appears to enable me to...
Install the latest Epson drivers from their support site as it looks like a part of the DLL structire has been lost that manages image manipulation. Also check that all Windows updates have been carried out.
Apr 13, 2009 | Evesham Evolution Blue Beast...
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
Monitor goes black but the green light stays on. I turn the power button off and then back on and it comes back on. It may stay on for a few seconds to several minutes.
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on green, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
The inverter is the board that supplies power for the backlights to turn on. The backlights
provide a light.for the LCD Panel(provides color and is the logic. ... similar to a projector.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
Sep 18, 2008 | Computers & Internet
Desktop background image shows half
Right click on blank part of desktop - select 'Personalize'
Select 'Display Settings'
Click on screen 1
Check resolution is set to high.
Click Apply
Click OK
Sep 12, 2008 | Sony VAIO GRX550 Notebook
I HAVE JUST INSTALLED CREATIVE VIDEO IM PRO WEBCAM ONTO MY COMPUTER. THE WEBCAM REGISTERS AS GEING INSTALLED. THE GREEN LED LIGHT IS LIT. HOWEVER, WHEN I TRY TO USE NO IMAGE APPEARS VIA THE CREATIVE CAM...
Does it display as a black image, a white image or static? You most likely have 1 of 2 problems. Either your camera (the actual lens if you want to be technical) may have been damaged or you are having an issue with drivers. Go Start>Control Panel>Administrative Tools>Device Manager. Under Imaging devices your web cam should be listed. Double click the description and post back with what the information from that window.
Sep 11, 2008 | Computers & Internet
No live picture on Benq digital projector
seems to me like your acer laptop's display is configured " extend my desktop to this monitor", that's why you can only see the desktop background. Go to your display properties and change it to clone display or uncheck the extend display option.
Mar 04, 2008 | Computers & Internet
Apple PowerBook G4 Mac Notebook Logo
66 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
