Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dishwasher error F1 Fllod switch has been activated
How to deactivate the fllod switch
  • 770 Answers
Remove the drawer and dry out the sensor on the board below you will most likely have to replace the actuator motors that hold down the lid
Posted on May 20, 2008
SOURCE:
My acadia 2009 3.6ltr, v6 engine - its fllod in fuel and engine light comes on and misses. replaced air flow sensor and spark plugs Noted white smoke comes out of silencer with fuel smell?
Scan the computer for trouble codes and see which cylindr/s are misfiring. You may have a defective ignition coil causing your problem if the spark plugs have already been changed
Feb 15, 2016 | Cars & Trucks
No spark
Try new spark plugs first, install them and see if it starts..if it won't start, try to fllod it.. them remove the spark plugs and make sure the plugs are wet when you remove them, this proves you are getting gas to the cylinders. No spark...then you will need a factory service manual to check the resistance values according to the manual for the pick-up coil, the cdi box, the main ignition coil, the plug wires. Check the on/off switch on the handlebar if it has one.
Jul 26, 2014 | 2001 kawasaki EL 125 Eliminator
Dishwasher error f1
The manual states that fault code F1 means that the flood switch has been activated. They recommend turning off the water and power to the unit and calling them. Their phone number is: 1.888.936.787
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/529543CDD605userguideUSCAw.pdf
Nov 26, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
My GE washer is leaking from the bottom when it begins to fill. the tub is also loosey goosey. I have a fllod in my kitchen need help?
Sorry about the flood in your kitchen. I take it that your GE machine is a front loader. It sounds like the rubber seal round the door is perished or damaged. When water starts to fill the tub the "faulty" seal lets the water back out again.
The seals are not easy to replace by the average DIY person but can be done. If you choose to replace the seal yourself let me know and I can perhaps talk you through it.
Hope this helps.
Mar 04, 2011 | Washing Machines
F1 error
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jul 12, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
My fisher and paykel dishwash has and error F1
Since you did not provide the specific model, I checked a few different models at the FisherPaykel website and F1 appears to mean your flood switch has been activated and to shut off power and call a repair man.. Please provide specific model number and maybe I can assist you further...
Sep 21, 2008 | Dishwashers
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
79 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
