My laptop is in a boot loop, boots up and turns off before loading the os. I have the key sticker on the back but cannot read the os version.. I know it is Vista home but don't know if it is basic or premium.. is there a way to find out what version the key belongs to? I need to find out before I reinstall the os..
    Guru:
  • 1,481 Answers
Windows boot files are corrupt...
it may not make any difference...as youhave to re-install the OS again....
but if you have the recovery CD that came with the noetebook then try use that CD to recover the OS
or
if you have the original WinVista CD then try do a repair of the OS
if all these fail then i am sorry only a reinstal;l of OS can solve the issue....
visit my site for more details on installling Win OS(XP)
installling Win Vista is similar
www.sureshayyar.110mb.com
Posted on May 10, 2010
Testimonial: "thanx.. I kinda knew this already.."
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
What do i do when my emachines laptop loops the title screen
Is it on a boot loop ?
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Boot in safe mode or the operating system equivalent. Windows, Unix/Linux and Mac operating system have a mode that will load the minimum software needed to boot. This is a standard approach in troubleshooting, as it only supports the minimum hardware needed to complete the boot into the operating system. Once you are logged into the computer, device drivers can be updated, software removed and so forth. To boot into safe mode in Windows, hit the "F8" key when the computer first starts up to get a submenu. From there select a boot option. Many choose "Safe mode with command prompt" as this will go line by line through the boot process, allowing you to isolate where the problem might be. To boot into a different run level in Unix/Linux, it depends on the version of Unix/Linux, but most have the option of a "recovery mode." During boot hit the "Esc" or "E" key and select the mode appropriate such as "drop to root shell," etc. If you have the ability to get into command shell, enter into run level 1 (single user mode) by typing in "init 1." To start in safe boot on a Macintosh laptop, hold the "Shift" key as it boots up. This forces a disk check and loads minimal software in efforts to complete the boot process, much like the other operating system's "safe modes." Check to see if your laptop is overheating. Laptops have a greater likelihood of overheating than desktops. Either touch the laptop or download an application such as Mobile Meter to check laptop temperature. If it is running hot, try using canned air to clear out of vents, etc. Also, elevating the laptop off of its resting surface allows greater airflow in and out of the laptop
Feb 18, 2013 | Computers & Internet
Acer aspire one model zg5 is in a loop of erecovery management and gives error message cannot format the object drive
If you mean laptop is in boot loop ?
hope this helps
Nov 27, 2012 | Acer Aspire One PC Notebook
Dell inspiron will not boot in safe mode . goes round in loop . if you put an xp setup disk in it still goes to loop
For your computer to read the Windows CD you need to change your boot mode to CD/DVD drive first. You need to access your BIOS which usually can be done by either pressing F2 or del when you first power on your computer. Once your in the BIOS look for the boot order option and make CDROM as the first boot device, save settings and restart your computer. When the XP cd is read, it will show you Press any key to boot from CD... and you need to press any key right away. It should read the XP disc and doing a repair is another story.
Jul 25, 2011 | Computers & Internet
Attn: Experts, I want to erase every thing on my computer and start over how ever I can not find my start up disk, is it posible to down load the start up info or perhaps would it be posible to have you...
Sir, you will need to make use of a recovery disc or a retail version of an operating system disc in order to reload windows. i dont think you'll be able to download a licensed of windows copy over the net. what you can download are the free OS like Ubuntu.
Dec 03, 2009 | HP Pavilion dv9000z Notebook
My os boot disc isn't responding is the disc bad or the hard drive bad
What error do you get?
Are you talking about the System CD or harddrive that gives an error?
Jul 17, 2009 | Toshiba Satellite A45-S151 Notebook
How to reformat R52 ibm thinkpad
Your laptop should have come with a recovery disk, you will need to boot to that disk following the onscreen steps for formatting and restoring the operating system files. Furthermore, if your system did not come with a recovery disk, or you have a Windows XP/Vista disk you can boot to that instead.
Windows XP Install:
After the installation system boots, the setup prompt will prompt you for searching the system for previously installed versions of Windows; bypass the recovery option after the search is complete. The setup will then display a list of Hard Drives to install Windows; follow the key for deleting the partition (press "D" to delete). Once the partition has been deleted highlight the "free hard drive space" and press "Enter" then you will be prompted to format the drive and install Windows. Moreover, you should right down the Windows Product Key off the sticker on the bottom of your laptop; you'll be asked for that key after the setup restarts your computer assuming you are using that license for that version of Windows.
Windows Vista Install:
When you boot to the Vista DVD you will be prompted to enter the product key as soon as the setup loads. Select the Hard Drive with the mouse, then left-click the format button on the right pane. Continue with the installation.
Nov 29, 2008 | IBM ThinkPad R52 Notebook
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
