Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I hooked a audoteck amp in my truck it work when i got it from a friend now it dont turn on where do i start to find out the problem
    Problem Solver:
  • 7 Answers
Start with the fuses bro
Posted on May 14, 2010
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
My 1988 chevy 1500 350 truck died on me at a stop sign and would not start back it would turn over but not hit a lick! so i pulled it home and changed the ignition module it tested bad at the store. it...
I'm just thinking out loud. Turn the crank by hand while you watch the rotor, they should move together, if not, you got a problem.
Can you check cylinder compression, if compression is really bad, you may never get it to run right?
In the past on older vehicles, some of the them, the check engine lite wouldn't work, but, I could hook up a scanner that shows live engine data, hook- up to the aldl, it would show engine data, of course it wouldn't show codes.
Mar 11, 2017 | 1988 Chevrolet K1500
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
2003 Pontiac Grandam wont start
if you are not hearing the pump turn on there's a good chance that its the fuel pump most gm's have a faulty wiring on the fuel pump harness id check the relay and wiring if theirs power to the pump but not crank that would be it id get a gm pump not a carter better to use oem
Sep 27, 2009 | 2003 Pontiac Grand Am
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
37 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
