Question about Roper REX4634KQ Electric Dryer
Load takes more than one cycle to dry. cleaned vent.
  • Roper Master
  • 43,501 Answers
Hi, If you have a gas dryerload takes more than one cycle to dry. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 11, 2010
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My dryer seems to be heating up but the clothes take two cycles to dry.
sounds as if the vent is restricted, take vent tube off, dry a load of clothes. Clean vent tube, and you may want to clean the inside of the dryer,also. Hope this helps Tim
Apr 04, 2011 | Frigidaire Electric Dryer
Maytag gas dryer won't heat up!!! It takes 6+ cycles to dry 1 load! What are the most common problems?
The main cause is a plugged exhaust vent in the wall. Try disconnecting the exhaust vent from the wall and run a normal load. If the load dries properly, then you will need to have the exhaust vent professionally cleaned.
Good luck
Sep 25, 2010 | Dryers
Dryer takes long time to dry. usually 2 or 3 cycle. Filycter is cleaned after every cycle. Vent hose is not blocked
This complaint usually is attributed to clogged exhaust venting somewhere. As a process of elimination, remove the exhaust venting from behind the dryer and run your loads. If the dryer dries clothes properly, then your issue is definitely with the exhaust venting (e.g.: inside wall, attic, etc.). If possible, check the entire path of exhaust venting or contact a vent cleaning company.
Apr 14, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is less than a year old and we clean the filter after every load. checked the vent hose and its clear with no...
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Nov 23, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Takes too long to dry- element cycles on and off - line draw 23 amp
Clean and straighten the exhaust vent.
In fact, remove it and run a timed load for 45 minutes to verify a blocked vent problem.
Aug 12, 2009 | Whirlpool Dryers
Takes for ever to dry cloths
Remove the connecting vent from the rear of the dryer. Do a timed load a 50 minutes. If it is dry, clean out the connecting vent and the wall vent.
Jun 27, 2009 | GE Dryers
Takes multiple cycles to dry one load
Clean the dryer vent all the way to the termination site and then clean inside the vent in the dryer. Make sure it is clean of lent. The blower assymebly can also become clogged as well but try the vent hose first. If it is completely clean and it's still haveing trouble, it could be the thermostat on the unit and it is not allowing the dryer to cycle properly.
Apr 10, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Roper REX4634KQ Electric Dryer Logo
591 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
