Question about Brother HL-2040 Laser Printer
Paper light says on.. wont reset after jam is cleared
Hi:
I cleared a paper jamb from the rear rollers as instructed . the out of paper red waring light will not reset so printer will not operate.. any clue to why? Where is the paper jamb sensor located?
  • 3 more comments
  • Anonymous Mar 28, 2008
    yes
  • Anonymous Mar 30, 2008
    have the same problem cleared jam and can not reset the red light.
  • nicebwoy Mar 31, 2008
    Had a paper jam. Got the paper out entirely but the red paper light stays on and printer will not operate.
  • Earl291 May 21, 2008
    I pulled a jammed paper out of the printer through the roller and now it won't print. It makes all the sounds but won't pick up paper from the tray. No paper lights or other lights come on except for the green light. What to do?
  • Anonymous Jan 17, 2009
    I didn't even have a jam and my red light won't stop blinking
  • 3 Answers
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Posted on Apr 03, 2008
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
My hp photosmart c7250 will not clear printing jam. after reseting, the rollers keep running until it times out then displays a print jam.
Sounds more like an out of paper response rather than a jamb. Make sure the pickup roller can actually catch the paper. Use a polymit to roughen the rollers slightly in the slot where the paper is contained. If you take the paper out and look down the slide that holds the paper you will see two or sometimes 3 rollers They can become shiny and fail to grab the paper. Make sure you use proper printing paper and not photocopy paper as this is the stuff that has resinous coating that causes rollers to become shiny.
To also ensure that there is not a tiny piece of paper covering the detection eye for paper jamb use a piece of stiff card and run it through the paper path with a little assistance from you pushing it while the roller turns. This will often remove any tiny bits of paper or waxy substance from the eye.
Please rate my help++++Thyanks for using FIXYA
May 09, 2010 | HP Photosmart C7250 All-In-One Thermal...
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
Printer starts to grab paper then paper jambs.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks! mannu_rakesh
Sep 09, 2009 | Brother HL-2170W Laser Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Says Paper Jam But No Paper In It
Hi
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
169 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
