Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Too hot wather/ thermostat problem
My water heather overheats the water. I know is a common problem but I tried all the normal troubleshooting and didn't work. I even got a new water heather today and it does the same...even on low temperature. After I hooked it up, in 20 minutes you couldn't hold your hand under the water. It happened the same with the old WH and after it worked like that for half a day the thermostat cracked. I think is something external...I have a separate electric line for that heather, on a 30amp brake. The same line that worked fine for a year. However, the line is not one straight wire, there is a junction. Does anyone know what could cause the malfunction of the thermostat? When I turn the electric break on I got all readings okay...240 between 1 and 3, 2 and 4, and at one of the element (this is a brand new 40GA water heather that I just bought this morning). If I take the wires from the WH and hook my dryer it works just fine. Any advice would be helpful ...On my old WH it burned 2 thermostats, neither of times the electric break turned off.
  • Anonymous Mar 19, 2014
    water heather was working and stop not even the power ligth is on
  • 26 Answers
Its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
Posted on May 10, 2010
Is this thermostat wiring correct for this Rheem water heater? also it only has one thermostat...shouldnt there be 2?
Heather, first know that most water heaters are 220 volts and are dangerous to work on unless you know that the power is off. Second it is hard to say any more without knowing the model number and the make. Third from the picture, a thermostat breaks the current in one side of the circuit and that appears to be depicted. There are usually TWO heating elements not thermostats.
Feb 09, 2017 | Rheem Water Heaters
What would be the cause/s if the water heater was to overheat?
THERMOSTAT, inside or underneath the temperature control.
If the heater does overheat, the temperature/ pressure valve on the side of the heater will leak or spew water. This is so that the water heater does not explode. It is far more common for the valve itself to go bad.than the thermostat. The temperature/ pressure valve is a common replacement part. The thermostat is not available as a replacement part on most tanks.
Mar 29, 2016 | Water Water Heaters
Heater element only gets 120volts. Should be 240v, correct? Water does not heat up.
Testing voltage on heater can be tricky since elements can test 120Volt to ground all all times.
This is because thermostats only turn off 1 Hot leg in the 240Volt circuit, while the other hot leg remains live. Each hot leg in 240Volt circuit is 120Volt.
http://waterheatertimer.org/B220C.html#120-240
Troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Try following things in order: Press reset button. Test elements. Replace thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add comment.
Apr 29, 2013 | Water Heaters
We have a reliance 600 about 4 years old. Recently when you turn on the hot water you get a lot of air out of the line. Also the other day we had scorching hot water and then no hot water. We reset the...
1) Reliance 606 Electric water heater, AO Smith subsidiary.
Good brand.
Copy following links:
2) First: Test elements using cheap multimeter from hardware store.
Next: If elements test OK, then replace both thermostats.
3) If that doesn't solve problem, then add comment Jan 2013 and report what you find.
Jan 26, 2013 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
Nov 25, 2012 | Rheem Water Heaters
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
More resources:
Oct 03, 2012 | Water Heaters
Water was much hotter this morning, actually steaming when faucet turned to max. I checked thermostat & reset button, seemed to be normal. I shut off power and pushed reset button, waiting for it to...
I would try it again and if water temp is still to high then I would adjust thermostat down to say 120 degrees and see what that does.If problem continues I would replace thermostat. Thank you
Dec 20, 2010 | Reliance & 50gal Electric Water Heater
Water heather does not com on when water is truned on wide open
when to local dist. got owners manuel which after installing 4 of these uints the person impersonating a plumber took with him. easy to understand tbl shooting. resolved tbl. thanks
Jan 05, 2010 | Noritz Commerical Tankless Water Heater...
No hot water
Is hot water present when opening the drain valve. Use a bucket to catch the water. Adjust thermostat from high to kow then prefered detting. Make sure hot water out line does not have a closed valve. If gas, ck pilot. If electric, elements may be damage if heater was powered up before or while initial filling.
May 11, 2009 | Water Heaters
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
80 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
