Question about LG 42PC3D 42 in. Plasma Television
Hi my LG 50PG20D-aa shut down after beeing on for approx 5min this morning. The unit is only 1.5 yrs old. I have checked connections and changed power suply. It remains dead. Is there a circuit breaker in side or fuse? Any help appreciated.
  • 458 Answers
SOURCE: TV will not power on
There is not an internal reset for this. You would need to check what voltages you are getting from the secondary side of the power supply, this would then indicate if the problem is with the main board not starting up the system or if the power supply has a fault. If you have a multimeter then you can carefully check for 24v 5v & 12v supplies. If you are not getting any voltages then the primary side of the power supply may be at fault. The first thing to check would be the fuse at the incoming mains supply on the power board, if this has blown then suspect one of the senmi-conductors & check to see if any of the capacitors are swoolen if so replace them.
Posted on Dec 08, 2009
  • 579 Answers
SOURCE: Help with repair for LG 2055ST
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Posted on Dec 31, 2007
  • 2335 Answers
SOURCE: No signal on tv
Since the TVs are less then a year old, they're still under manufacturers warranty. LG Contact Information Main support number 1-800-243-0000
Email: supportcustomerservice@lge.com
Posted on Aug 15, 2008
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
daddyo742001
  • 70 Answers
SOURCE: I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
Posted on Jun 28, 2009
When i go to turn on my LG 50PG20D-AA plasma tv, the green power light turns on for a couple seconds, the LCD turns on, then flicks off again, it keeps repeating the process until you disconnect the power...
everyone is wrong here.
Disconnect the power from the mainboard the board down on the right hand side.
now short out the auto_gen with a peice of wire while tv unplugged.
after this process plug it in.
You should see a test pattern this will rule out Y-sus and Z-sus problems.
Problem will be main board.
Dec 28, 2012 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Viore DLP TV keeps shutting itself off
contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
Dec 06, 2008 | LG 42LC2D 42 in. LCD HDTV
No water collection
Check if the fan is running by putting your against the grill in front or back of the unit.
Jun 23, 2008 | LG LD65EL Dehumidifier
I have an LG 60" DLP that is approx 4 yrs old. There are light blue hazy area showing up on the lower right, and lower left side of the screen.
video card too much heat, is the LG itself real warm after a short turn on time? take monitor and hook to another PC and see if problem is there also. check connections in back of PC and LG are secured.
Jun 22, 2008 | Computers & Internet
LG 42PC3D 42 in. Plasma Television Logo
402 people viewed this question
Computer Repairing
Computer Repairing
