Question about Kenwood KDC-MP922 CD Player
What does the colors of the wire mean? like black is ground... power is yellow with red stripe.... i need to know all of them please!
    Problem Solver:
  • 8 Answers
I found the owners manual for ya your diagram is on page 50 here's the link
http://manual.kenwood.com/files/B64-2458-00.pdf
hope this helps
Posted on May 10, 2010
Ineed the diagram for toyota tercel 99 fuel injector wires colors for each cilinder
This '99 Tercel is not sold in the U.S., so maybe can't help. car models listed are Avalon, Camry, Celica, and
Corolla.
Nearest to a Tercel would be the Corolla, so here is the wire colors for that: the power wire for all injectors is the same spliced wire- it is a black/white wire. The ground wires for each injector (the wires that go into the ecu for internal grounding which causes the injector to pulse), are as follows: #1 injector is a yellow wire, #2 injector is a white wire, #3 injector is a B-R wire- don't know if that means a brown and red stripe wire, or a black with red stripe.
#4 injector is listed as a B wire- just the single color, I think that would be black, not brown. And so I think #3 would be Black with a red stripe.
there you go, maybe it will help you, maybe not, but you get the picture: all the power wires are the same color, the ground wires will be the different color wires.-
May 30, 2017 | Toyota Cars & Trucks
I need a COLOR wiring harness diagram for john deere la130 riding landowner. i do not have manual. need to know if im missing any parts. i need to know where the colored wires go. -red -red & black...
ok i found a picture diagram for what looks like to be your harness but i you need to get the numbers off the wireing harness its self
these can be very helpful in locating the proper diagram and wireing instructions for this harness
now the pictures and color codes is on a picture at bottom of the link i put in here so hope the link helps youll have to zoom the pic
there is two types of harnesses with the four points (meaning ends)
one is for the clutch and one is for back panel behind steering wheel the guages red is always hot red and black striped is key accessorie hot
yellow is usually the on position once key starts to engage blades or clutch
the blacks are grounds
need a good pic of this harness with out hand in way and closer but showing all the end points ive worked on these but i would rather see it better with more pics if possible
Nov 09, 2013 | Cars & Trucks
Deh 405 wire harness color codes. Need to know what each wire is to avoid incorrect hook-up. Thanks
These are the general wiring harness colors and their respective connections:
+12 Volt Battery Wire YELLOW (i.e. constand power for memory)
+12 Volt Ignition Wire RED (i.e. power only when key is ON)
Power Antenna / Amp BLUE/white stripe
Chassis (NEG) Ground BLACK
Front Left Spkr (+) WHITE
Front Left Spkr (-) WHITE/black stripe
Front Right Spkr (+) GREY
Front Right Spkr (-) GREY/black stripe
Rear Left Spkr (+) GREEN
Rear Left Spkr (-) GREEN/black stripe
Rear Right Spkr (+) PURPLE
Rear Right Spkr (-) PURPLE/black stripe
Cheers,
"If this has helped you, please rate this solution with thumbs up"
Jul 09, 2011 | Pioneer Car Audio & Video
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Can i get wiring diagram of sterio for Acura Rsx 2004?
Generally there are two types of wires , power , and sound. The power wires will usually be black , red , and yellow or orange. Might also have a blue one. Black is ground , Red is constant power , yellow or orange is accessory power ( only energized when key turned on) .
If you have a blue wire , it sends out power when stereo is on , to power an electric antenna or turn on an external amp. All other wires will be in colored pairs. For example Green and Green with a black stripe , Grey , and Grey with a black stripe , purple and purple with a black stripe.......These are all speaker wires , the solid color one is the + and the one with the stripe is the - , EG: Grey might be right front + , and Grey with black stripe would be right front -
May 03, 2009 | 2003 Acura RSX
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Kenwood KDC-MP922 CD Player Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
