Question about PfaFF Hobby 4260
My Pfaff 1032 sewing machine feed dogs won't advance fabric or
My Pfaff 1032 feed dogs don't advance fabric or go in reverse. I tried cleaning out the lint, but the feed dogs just go up and down, they don't go back and forth.
The original problem that I had was repeatedly breaking needles, but when I consulted with someone, she noticed that the feed dogs weren't working correctly and figured the needles were breaking because I was pulling the material through, since the feed dogs weren't doing it.
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
SOURCE: thread bunching underneath fabric as I sew.
You may need to take off the housing that covers the whole dog mechanism. You will need a screwdriver to do this. Blow out the area around the tension gears and dogs, check for loose or disconnedted parts, and re-oil the gears. Fleece fuzz usually collects where you can't see it. This was the problem with my machine that had the same symptom.
Posted on Jun 03, 2008
  • 323 Answers
SOURCE: pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
set your tension to 5 and try it.
sewman7
Posted on Jun 18, 2008
  • 323 Answers
SOURCE: i have an 1130 bernina
The 1130 does not have a consumer adjustable presser foot. Check to be sure you are using the correct presser foot .Some feet are slightly different in height which is how the pressure is regulated. If this is not your problem it will need to be seen by a technician.
sewman7
Posted on Jul 14, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
I have a new home excel 23lL sewing machine and the fabric won't advance
check the position of the forward/ reverse setting
near the middle will not advance the material
take it in for a service
Oct 25, 2016 | New Home Sewing Machines
Hello, I have a very old but wonderful Pfaff 260 automatic and the feed seems to be going backwards but is not pulling the fabric at all?
First, verify that the stitch length is set high enough that the feed dogs should be pulling the fabric to create a stitch.
If you have not recently oiled the machine, the feed dog mechanism may be stuck due to old oil that has solidified. Pick up some liquid Tri-Flow Synthetic Lube. While gently rocking the handwheel, apply a couple drops everywhere that metal rubs against metal. Do NOT oil rubber, leather, or synthetic parts!!! Don't forget to hit the spots under the sewing surface, ie the feed dogs, bobbin area, etc. Also, move the levers and selectors and hit those with a couple drops of oil. If things are still a bit sluggish, you can apply hot air from a handheld hairdryer at the interior of the machine. The heat will help loosen things.
P.S.--I picked up a frozen Pfaff 260 at the thrift store for $25. Used the above method to get things loose and now it sews beautifully!!!
Sep 02, 2016 | PfaFF Sewing Machines
Fabric not advancing
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Nov 23, 2013 | Janome Sewing Machines
Feed dogs not advancing fabric, only moving up and down
Normally it's good form to give us the make and model number of your machine.
Sounds to me your problem began with operator error. Get in the habit of grasping the threads and holding them as you take your first few stitches. Also make sure your take up lever is in the UP position before you take your first stitch.
Now, look to see if your feed dogs are lowered... if they are put the back up. If this happens again... you've got a warn or broken part.. and you should return the machine. Clearly your "repairman" sold you a lemon.
Mar 14, 2013 | Sewing Machines
My pfaff will not feed fabric forward
Check to see if you've accidentally lowered the feed dogs.
Jul 06, 2012 | PfaFF Sewing Machines
Problem with feeder dog
if you have the manual to the machine then you can see where
the feed dog lever is & check to see if it's in the up position
also you can take the machine in to be checked to see if the feed dogs
need repairing or replacing
Jun 12, 2012 | PfaFF Sewing Machines
My pfaff 1471 sewing machine keeps breaking the needle
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
6. Check top thread tension
May 28, 2012 | PfaFF Sewing Machines
Heavy material feed dog
To the very best of my knowledge (and I've been full time as a manager / owner in my family sewing machine sales / service business for almost 30 years (with many more part-time before that), I know of no "heavy material" feed dog that has been available for the Pfaff 130. Please keep in mind that the 130, while pretty heavy duty (especially compared to many of today's machines), was never manufactured or intended to be heavy duty in the sense of sewing heavy items such as uphaolstery fabrics (canvas, nagahide, etc.). It was produced with the intent of being a reliable household (non-commercial / industrial) machine with the purpose of sewing light-to-moderate heavy metrails. What exactaly are you trying to sew that leads you to the request of using "heavy material" feed dogs or that you feel Pfaff produced / manufactured such an item?
Best regards,
Dave
May 06, 2009 | Sewing Machines
Sewing Machines Logo
287 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
