Question about Kelty Base Camp Framed Baby Carrier
I need a replacement part for the adjustable leg. It broke right on the hinge. any suggestions?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
The fridge door squeaks and makes a clunk sound when opened. Looks like the top hinge is missing a small red plastic clip. There is one on the freezer hinge but and empty slit where it should be on t
it could have had one and it broke . go to local home improvement store and ask hardware people about nylon washers .top hinge needs removed and just slipwasher into place and replace door hinge .
Jan 19, 2015 | Refrigerators
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
One of the legs of the sunglasses broke off. The hinge is still attached to the leg of the sunglasses.
You may need to replace or rescrew on the other leg, usually done using a small glasses repair kit.
Apr 19, 2011 | Lacoste Clothing Accessories
When I open bottom or top fridge doors they swing all the way open by themselves instead of staying put partially open
The fridge needs to be leveled better...
When the doors swing open then gravity takes over and pulls the doors open the rest of the way...
to fix this adjust the legs of the fridge so that it leans just a bit away from the hinge side and back just a bit...then the doors will swing closed by themselves...
The back legs may have to be shimmed and the front leg adjustments are usually right behind the front cover at the floor...sometimes there are screws there to adjust the back legs from the front also...
heatman101
Jan 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
Someone suggested replacing the hinge.
hinge is operated by springs that connect to the base of the unit where the adjustment legs are. The tension on thew door can be adjusted by moving the spring to the next hole on the base. Remove bottom panel of the unit at the floor area and look under the unit you will see the spring and the holes on the base frame that they hook to. Move the spring back for more tension and forward for less.
Hope this helped
Dave
Mar 17, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
The locking hinge is broke where it folds and won't stay unfolded
Problem suggests that you have identified the defective part. Can you try extracting the part using the proper tools and taking it to the nearest hardware store which deals with the spares of this kind to pick up replacement.If you can do that it will be great else you consult a service engineer for assistance.
Jul 20, 2006 | SafeTech Double Jogging Stroller
Kelty Base Camp Framed Baby Carrier Logo
101 people viewed this question
Top Kelty Baby Gear Experts
Andrew Taylor
Andrew Taylor
richie46
Dorel UK
Dorel UK
Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
