Question about Insignia IS-LCDTV32 32 in. Television
Color and tint looks different. There is a green hue to the screen, and adjusting the tint and color does not help.
  • 38 Answers
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
Posted on May 10, 2010
Turned on computer today and my screen is blue green, does not change using monitor buttons?
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Apr 11, 2015 | AOC Computers & Internet
Tv screen is high in green color what settings do I need to be on
If your TV has a color temperature setting; it is probably on medium. Try it on warm. This will decrease the amount of green and increase the red.
Otherwise you will need access to the tint/hue controls; adjusting it more toward red will help.
Dec 21, 2014 | Televison & Video
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Green hue/tint
Need to do the alignment feature where it refocuses the light beams. Convergance. Look through the set up. Different magnetism and shaking of the set has thrown it off most likely. Auto focus maybe what its called.
Apr 15, 2010 | Sony KDS-R50XBR1 50" HDTV
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Green hue instead of actual colors
Short on the crt board, look in the green area. Probably an small 3 leg transistor.
Sep 04, 2007 | Sharp 27L-S300 27" TV
Insignia IS-LCDTV32 32 in. Television Logo
333 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
