Question about Toshiba Satellite R10-S802TD Tablet PC
Any time i insert a flash drive into my system usb port, the system does not recognize it
    Guru:
  • 1,481 Answers
Try it in another PC...if it reads there then
format the flash drive in another PC and then try in this PC....
else
could be a problem with device drivers.
Right Click My computer.
Select Properties
Select HARDWARE tab from the properties dialogue box
Select Device Manager.
Now Search for Universal Serial Bus Controllers.
Reinstall the driver.
else
the next option is to remove and again insert the pen drive and let it install it so that you can browse it. Do cancel at the time when it displays you found a new hardware
pls leave a feedback...
reg
Posted on May 10, 2010
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Starts up. Password required but keyboard not typing correctly. Blue tooth keyboard not recognized.
The most likely cause is that the keyboard needs a new battery in it, inserted on the underside. After that it may be that the small keyboard comms dongle in a USB port is not making proper contact. Pull that out and insert it a few times.
Mar 26, 2016 | Tablets & eReaders
I plug my zeepad into my comp with a usb plug it tells me it's looking for software to download but some other screen pops up asken me to put in the software disk that came with my device but I never...
Same problem happens to me when I insert something into one of my computer's USB ports, such as a flash drive, it doesn't get recognized. This happens with things other than just a flash drive as well, like my iPod. I have numerous USB ports on my computer, but they all act the same. I'll insert a flash drive and even after it's not automatically recognized, I'll go into "My Computer" and it shows all the "Removable Disk" drives as being empty. I'll click on one and a prompt will come up and say, "Please insert a disk into drive F" or whatever drive I happen to click on. I've tried this with all the drives but to no avail.
http://mhelpdesk.com/field-service-management-software/
Oct 06, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Flash player doesnt work
Flash Player the software from Adobe (Adobe Flash Player)? or are you talking about when you stick a Flash Drive (Jump Drive) in the USB Port the system does not recognize it?
Apr 06, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Tablet won't recognize USB drive
The guy's that can fix this are in the uk Sumo Technologies they fix all DTR products (address on DTR's website)
Jan 22, 2009 | Tablets & eReaders
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
"USB Device Not Recognized" - any usb device
It May just be a hardware problem... try putting in some new usb ports.
Dec 14, 2008 | HP Pavilion tx2120US Tablet PC
Gateway Pen Drive .... not recognized on Windows XP
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Nov 22, 2008 | Gateway M275 Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
56 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
