Question about Whirlpool Duet GHW9150P Front Load Washer
Vibration problem how do I remove front cover to check shock absorbers?
  • Whirlpool Master
  • 43,501 Answers
There are a couple of screws at the very btoom of the bottom front panel...take these out and then pull down on the panel...it helps to set the front of your washing machine up on blacks first...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 10, 2010
Bike vibrating in pickup time back side
Hi Pradip,
The reason for this problem may be because of you chain sprocket, check if its placed tightly, Also check your Bore Piston.
Apr 30, 2014 | 2005 Bajaj Pulsar 150
I need to remove the entire passenger side rear suspension. Does it go through the trunk or the back seat? If so how do you remove the back seat?
REMOVAL & INSTALLATION 1983-86 Models
  1. On 4-door sedan, remove the package tray and vent duct.
  2. On hatchback, remove the speaker grilles.
  3. Disconnect the brake line from the wheel cylinder. CAUTION
    Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
  4. Remove the brake line from the brake hose.
  5. Disconnect the brake hose from its bracket on the shock absorber.
  6. Loosen, but do not remove, the nut holding the suspension support to the shock absorber.
  7. Unbolt the shock absorber from the rear arm.
  8. Unbolt and extract the shock absorber from the body. To install:
  9. Attach the shock absorber to the body and tighten the 3 nuts to 17 ft. lbs. (25 Nm).
  10. Engage the shock absorber bracket with the carrier and install the hardware. Tighten the nuts to 119 ft. lbs. (162 Nm).
  11. Tighten the center suspension support nut to 36 ft. lbs. (49 Nm). There is a bearing located under the suspension support dust cover. Remove the dust cover and pack the bearing with multi-purpose grease. Once packed, reinstall the dust cover.
  12. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  13. Have the rear wheel alignment checked.
1987-88 Models
  1. On wagon models, remove the toneau cover holder.
  2. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  3. Remove the rear wheels.
  4. Using the proper size flare nut wrench, disconnect the backing plate hardware.
  5. With a flare nut and a back-up wrench, disconnect the brake tube from the brake hose and use a small plastic container to collect the brake fluid.
  6. Undo the clip and disconnect the brake hose from the shock absorber. NOTE: Before the axle bolts are removed, the axle carrier must be supported with a jack.
  7. Support the axle carrier with a floor jack and remove the mounting bolts and nut. Disconnect the axle carrier from the shock absorber.
  8. Support the shock absorber firmly by hand and remove the three mounting nuts. Remove the shock absorber from the body. To install:
  9. Position the shock absorber onto the body and support it firmly by hand. Install the three nuts and tighten them to 23 ft. lbs. (31 Nm).
  10. Attach the axle carrier to the shock absorber with the nuts and bolts. Tighten the nuts to 166 ft. lbs. (226 Nm).
  11. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  12. Bleed the brake lines as described in Section 9.
1989-96 Models
  1. On the 4-door sedan, remove the package tray and vent duct. On 1992-96 models, it will be necessary to remove the rear seat back.
  2. On the hatchback, remove the speaker grilles.
  3. On the wagon models remove the tonnue cover and rear seat back.
  4. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  5. Remove the rear wheels.
  6. Disconnect the brake hose and the ABS speed sensor from the shock absorber.
  7. If equipped with ABS, disconnect the Load Sensing Proportioning Valve (LSPV) spring from the lower arm.
  8. Disconnect the stabilizer bar link from the shock absorber.
  9. Support the rear axle and loosen the 2 bolts from the lower end of the shock absorber.
  10. From inside the vehicle, unbolt the upper support. Fig. 1: A rubber cap covers the rear shock absorber tower nut 89558p01.jpg
    Fig. 2: The upper shock absorber tower is retained by the center nut (circled) and three surrounding nuts 89558p02.jpg
  11. Lower the rear axle carrier and remove the two bolts.
  12. Remove the shock absorber from the vehicle. To install:
  13. Install the shock absorber assembly onto the vehicle.
  14. Connect the brake hose and the ABS speed sensor to the shock absorber.
  15. Connect the stabilizer bar link to the shock absorber.
  16. Install the wheel and tire assembly.
  17. During installation, please observe the following tighten specifications:
    1. Tighten the shock absorber-to-body bolts to 29 ft. lbs. (39 Nm).
    2. Tighten the shock absorber-to-axle carrier nuts to 166 ft. lbs. (226 Nm) on 1988-91 vehicles and 188 ft. lbs. (255 Nm) on 1992-96 vehicles.
    3. Tighten the suspension support-to-shock absorber nut to 36 ft. lbs. (49 Nm) on 1988-91 vehicles. On 1992-96 models, tighten the stabilizer bar link to shock absorber retainers to 47 ft. lbs. (64 Nm).
  18. Install the rear seat back, vent duct and the package tray as required.
Dec 18, 2010 | 1986 Toyota Camry
How do you replace shocks on 1991 buick skylark
REMOVAL & INSTALLATION Fig. 1: After you open the trunk lid, use a suitable prytool to remove the trim cover 86888036.jpg
Fig. 2: Some vehicles have a cover which must be removed to access the shock retaining nuts 86888037.jpg
Fig. 3: Unfasten the upper shock attaching nuts 86888038.jpg
  1. Disconnect the negative battery cable.
  2. Open the trunk lid and remove the trim cover. If equipped, remove the nut cover.
  3. Remove the upper shock attaching nut(s). If removing both shocks, remove one at a time.
  4. Raise and safely support the vehicle.
  5. Unfasten the lower shock absorber mounting bolts. One wrench will have to be placed on the bolt head side to retain the bolt as you loosen the nut. Usually a 15mm wrench is used to remove them. To install: Fig. 4: After the vehicle is raised and safely supported, use a socket to unfasten the lower retaining bolt 86888039.jpg
    Fig. 5: Remove the retaining bolt, then . . . 86888040.jpg
    Fig. 6: . . . remove the shock absorber assembly from the vehicle 86888041.jpg
  6. Connect the shock absorbers at the lower attachment and install the attaching bolt.
  7. Lower the vehicle enough to guide the shock absorber upper stud through the body opening, then fasten the upper shock absorber attaching nut loosely. Tighten the lower shock absorber mounting bolt to 35 ft. lbs. (47 Nm).
  8. Remove the axle support, then carefully lower the vehicle. Tighten the shock absorber upper nut to 21 ft. lbs. (29 Nm).
  9. If equipped, install the retaining nut cover, then install the rear trim cover. Close the trunk lid.
  10. Connect the negative battery cable.
Oct 08, 2010 | Buick Skylark Cars & Trucks
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Maytag Nepture washer shakes across floor
iff you remove the door assy 2 screws holding it on) andthe n the 2 screws opposite the hinge, youll be able to remove the front cover and look at the inner workings of unit, perhaps a shock absorber has broken causeing the vibration
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Shocks
rear
5955ba5.gif ------------------------------------------------------------------------------------------
front
Removal
  1. Remove front shock absorber-to-upper shock bracket nut and bolt.
  1. Disconnect the lower end of the front shock absorber bolt and nut from the U-bolt plate.
  1. Compress the front shock absorber and remove.
Installation
  1. Insert front shock absorber into the front shock absorber mounting bracket (18183). Insert bolt and tighten nut to 60-81 Nm (45-60 lb-ft).
  1. Attach the lower end of the front shock absorber to the U-bolt plate by installing the nut and bolt. Tighten to 60-81 Nm (45-60 lb-ft).
front
Feb 04, 2009 | 1996 Ford F350 Crew Cab
Shock absorber
kyb shocks ar the best thats all we use also check the "ruber" on the top make sure it is compresed together any gaps cause the " bump or pounding" noise
Sep 18, 2008 | 1997 Chevrolet Suburban
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Vibration problem with Frigidaire front load washer.
Can't tell you about your particular model, just some generalities:
Unless the shock actually failed from a defect, you might have broken or damaged something else. Check especially for wires or other parts pinched between the tub and other parts or the housing. Also, make sure the tub shaft hasn't broken or worn the seal at the rear or the seal at the front. If this unit has ballasts one of them may have broken or broken loose to cause the shock to break. I had one similar with that problem. Might want to take the ballasts off the tub or brace it to keep from stressing the bearing and seals. Mine had three ballasts, one large cast iron one on top of the tub and two concrete ones either side. One of the concrete ballasts broke and the tub vibrated and pinched wires and damaged seals and was totaled. If nothing but the shock is broke, it's probably worth repairing. However, the other shocks also have the same amount of wear, check them carefully first. Also, check the seals while you're in there. Use a digital camera and take pictures of everything before you take it apart and be very careful with wire routing. Most parts are held with (probably) metric and Phillips. Always unplug it to work on it and plug it into a ground-fault protected circuit. Best to set the machine up to run then plug it in remotely if possible.
Dec 19, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
