Question about Acer Aspire L100 PC Desktop
CD cannot be ejected
I have a problem to eject the cd, everytime I press the eject butted to cd remain stuck. Please advise.
  • 355 Answers
On most cd drives there is a small hole on the front. straighten out a paperclip and push it in the hole and it will push out the cd.
Posted on May 10, 2010
Microsystem CD wont eject
I know I've come to this late, but here goes anyway...
When you press eject and the CD starts to come out, but gets stuck when a little bit of the CD is showing, I lightly press down on the CD which 'releases' whatever was catching the CD and the eject completes.
Geoff
Feb 12, 2013 | Boston Acoustics MicroSystem CD High...
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Cd player will not eject holds 6 cd 2001 ls licoln says cd error
This happens to me as well, usually if you press and hold the eject button all of the cd's will be ejected. A couple of times I had to use another cd to kind of slide underneath the stuck cd to assist with it ejecting while I pressed the eject button.
Feb 24, 2010 | 2001 Lincoln LS
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Cd palyer won't eject.
nissan comes with a clarion radio that had eject problems. you are probably better off removing it and replacing it with and aftermarket radio.
May 31, 2009 | Car Audio & Video
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Nov 30, 2007 | JVC Arsenal KD-AR260
Acer Aspire L100 PC Desktop Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
