Question about Toshiba 55H70 55" Rear Projection Television
Blue colour failed to converge to green. Colour convergence adjustment horizontally failed to work. The set was purchased about 7 years ago, working perfectly. Before the malfunctioning, computer outputing of movies were shown (successfully). As the market value of the set is low, and I am wondering if the problem can be fixed without too much expenses. Regards Jianke Li
  • Jianke Li May 10, 2010
    The set is 57vw9ua not posted as 55h70, but I guess the principle is the same. The manual should be useful.
    Thanks
    Jianke
  • Jianke Li May 12, 2010
    The service manual is helpful, but my TV set is Toshiba 57vw9ua. And so I would be grateful if I could have a service manual for this brand.
  • 2,335 Answers
I can offer you the service manual for your Toshiba 55H70 Rear Projection TV. This will walk you through the steps of using Service Mode to adjust the horizontal convergence of the guns, as well as HIT & WD data. If these steps fail, the trouble will require replacement of hardware. If you are handy, it may be possible to source the parts listed in the manual for self-replacement.
I hope that helps.
_____________________________________________
Toshiba 55H70 Service Manual Download
Toshiba 55H70 Manual Download
Posted on May 10, 2010
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
My picture has broken into colour ghosting (it looks like a 3d picture without the glasses on). I'm guessing that this might be the failure of one of the colour bulbs. The wavey colour bands that I see are...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2011 | Hitachi 57F500 57" Rear Projection...
Panasonic Model #PT51HZ41E Blue is not converging, red and green perfect. Blue lines move but will not converge have replace STK392-110 checked all resistors what else could the problem be
On my Panasonic PT-56TW53, the down left quarter of the screen has a big colour distorsion. Convergence can adjust blue and red, but green is not able to show a straight line. Is tis a mechanical adjstment? Help would be great.
Feb 11, 2010 | Televison & Video
Convergence Issues...
pls check convergence set on remot cantrol.
pls . menu dispaly open select convergence adjesment see on the screen croos line is 3 colour Red /BLUE /Green. set up -down and right -leaft key to move colour cross line maching with cantrel and cross line is totaly white .pictur is natruly and normal .
Oct 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Poor colour balance
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 17, 2009 | Hitachi 46F500 46" Rear Projection...
Colour problem
6b5ee7e.png You may have a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Dec 31, 2008 | Toshiba 42H81 42" Rear Projection...
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
