Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Sony Wega KP-46WT520 no pic or sound 9 blinks
I have a Sony Wega KP-46WT520. Recently the tv has taken longer to display a picture once the power button is pressed and today it won't display a picture or sound. I have done some interenet research and found that I should count the number of blinks from the standby button. I have counted 9 blinks with a short pause 9 blinks and then a long pause follow by 9 more blinks. Does any one know what this means and what I need to do to fix it? Thanks for the help in advance.
  • 10,594 Answers
9 times standby red light blinks in Sony KP-43WT520 shows problem of "Zero Crossing Detector", its technical term taken from service manual.
Solution is to replace diodes D6116 and/or D6301 on G Board (power supply board) as above said diodes get open/ defective and causing that problem.
It is recommended to have qualified tv repairman to fix tv if you have no experience of working in tv circuit boards.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on May 10, 2010
Sony wega model#kp-46wt520 rear projection hdtv lamp
It uses 3 picture tubes which due to the age of the set are no longer available.
May 05, 2012 | Sony KP-46WT520 46" Rear Projection...
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
My sony Wega KP-57WS520 TV blinks 9 times and the picture and sound won't come on.
the blinking is an error code telling you that tv needs a new power supply.. have your tv serviced...
Nov 17, 2009 | Sony KP-57WS520 57" Rear Projection...
5 blinks on a sony wega KP-46WT520
needs convergence chips, stk392-570, and possibly one or more blown picofuses, you probably need a tv repairman, extensive soldering required.
Sep 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Where is the g board
Its the board that has the power cord plugged into it. It should be on the way on the left side when looking in the rear of the set.
May 27, 2009 | Televison & Video
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
KP-46WT520
IC8002 # 670581001 on D board .Ater replacing 3 diodes how many times does it blink now?
Jan 03, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony kp-46wt520 will not turn on
Mine was "G-Board"
(Power supply board)
Removed it myself and sent it here: http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Call number on here...
Its a sony place in Penn.
They repaired it for $88...tv repairman had quoted me $400
Dec 31, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
882 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
