I have a hotpoint top load washer, seeming to a 1992 model.
I have a top load washer, seeming to a 1992 model. Everything still works fine. The only thing is that I see oil comes out of the bottom. I am afraid of going to cause big problem in the near future.
  • Washing Mach... Master
  • 43,501 Answers
You are right...if there is more then a cup or so of oil from the transmission you are looking at a failure in the near future...in a washing machine that old I would not spend the money for the repair...
If I were you I would start shopping for a new one...
Here is a tip that will clue you in to one of the things that you may have to change when you get that new washing machine..
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
Posted on May 10, 2010
The dryer does not get warm everything else works fine just no heat seems as though the heating element has stopped working any idea on how to fix this
its more likely to be thermo stat if you take off the lid you will see the dryer unit on top of that there are 2 little round objects with 2 wires on each they are held in with little metal springs if you buy a thermostat kit they are easy to change
Jan 09, 2011 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint VBXR1070 washer tub will not spin. The motor seems fine and spins, but the belt seems loose and has apparently been rubbing on the metal support housing. Is it possible that the belt has...
yes, the rubbing could definately have damaged the belt, so I would begin by replacing the belt first. you may also have a problem with the clutch pulley which sits on top of the motor. if you remove the clutch you must replace the clutch clip as the old one will not hold again. hope this helps.
Oct 13, 2009 | Hotpoint VBXR1090D Top Load Washer
Frigidaire Galleria Front Load Washer.
Could be anything from lid switch to pc board to belt tensioner. Start with the cheapest and easier first with lid switch and belt tensioner.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code f 18 on hotpoint wd640 ? any idea Everything seems to be working except drium isn ot turning, i hace checked the obvious like the belt.
F18 usually indicates a communication error according to Hotpoints error code list, if you have tried everything that you can and it still does not work, then you are going to have to call an engineer.
Dec 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Hotpoint Top Load Washer LEAKING!! PVC pipe clogged? Help!
I have had the same problem with this washer so I tried putting it on Medium load and it works fine. Any time I try to put it on large load the leak happens every time.
Aug 24, 2008 | Hotpoint VBXR1090B Top Load Washer
Will not drain
probably the pump impellor is jammed. it behind the rear cover, disconnect the pump, its only small, and clean all the pipes. check the little impellor turns freely.
Feb 19, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
Hotpoint washer
  These older units had an insert in the agitator that would strip out.  Remove your agitator and take to a parts store. They should be able to help you out.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
