Question about Logitech Harmony 520 LCD Remote Control
Safe mode? what does that mean? - Logitech Harmony 520 LCD Remote Control
This means that the firmware on your remote needs to be updated. Please do the following:
1- Launch the software and log in to your account.
2- Click on 'Downloads' at the top of the screen.
3- Click 'Firmware' and follow the steps to update the firmware on the remote.
4- Update your remote.
Posted on Jul 23, 2010
When i boot my computer, it displays JPRGI is compressed. what does this mean
disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer
Jan 25, 2013 | Dell OptiPlex 360 Desktop Computer
Tip
How to make windows installer work in safe mode
Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
1.Safe Mode.
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then
net start msiserver
This will start the Windows Installer Service.
2.Safe Mode with Network
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by
net start msiserver
on Mar 15, 2010 | Computers & Internet
Tip
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
  1. Safe Mode.
and then net start msiserver This will start the Windows Installer Service.
  1. Safe Mode with Network
and followed by net start msiserver This will start the Windows Installer Service.
on Mar 15, 2010 | Microsoft Windows XP Professional
My dell is slow
First run your laptop in safe mode to enter safe mode press f8 on start up if you feel the difference in safe mode means post again
Jul 10, 2012 | Dell Inspiron Mini Nickelodeon PC Notebook
I turn on my compaq presario. However, when the microsoft logo appears it stops there and keeps on loading, which means the screen is black. I tried a hard reset and many other things, but it doesn't work....
Hi!
You can try restoring the computer back in time when date isn't yet present using system restore. I suggest you do it in Safe Mode, you can access that by tapping F8 as soon as you turn the PC on( I mean as soon as you press the power button). You will see a bunch of options, please select Safe Mode or Safe Mode with Networking. Then once you booted to Safe Mode, please perform a System Restore. Hope this helps.
Apr 17, 2011 | Compaq Computers & Internet
My car audio has gone into safe mode need codes to unlock it. vauxhall corsa sxi
Hi.
There is no code to unlock safe mode. Safe mode means that a fault has been detected and the unit goes in this mode (kind of forced stand by) to prevent further damage.
Disconnect battery ground cable and check the wiring at the back of the unit, a contact in the connectors or a short on wiring is common cause for safe mode.
When you disconnect the battery ensure that you have the anti theft code if needed. Anti-theft is different from safe mode. In that case you get Code on display, not Safe or the triangle sign.
Regards.
Ginko.
May 31, 2010 | Car Audio & Video
Hi I get a "signal out of range" message until windows xp starts. This means I can't get into safe mode or see start up messages. Any ideas please?
You see "Signal Out of Range" does not mean you cannot go to Safe mode or see startup messages. It shows up when you dont have a display. The refresh rate of your monitor is a little slow. So when you wana go to safe mode, press the Power button and start pressing F8 option and you will get the safe mode option and you will see startup messages when you will get one. Your computer is perfect. :)
All the best.
Regards,
Shrey
Oct 09, 2009 | HP L1955 19" LCD Monitor
What is safe mode?
safe mode is the mode which is used fix some problems like software or hardware conflict problems ...
safe mode loads with the minimum system files & drivers by using which you can solve the hardware conflicts & software conflicts problem easily ....
to go to safe mode you must press F8 before the operating system loads i mean in the starting of the system only..
Apr 15, 2008 | Compaq Presario 5000 PC Desktop
Dileep...
Apr 15, 2008 | Computers & Internet
My Safe won't open. What can I do?
hi
my safe menas safe mode.
if it then go to safe mode and go to start menu run and type CHKDSK THEN PRESSS ENTER
then wait untill u get y/n
press y
then restart u start in normal window,
try this if u say my safe means safe mode
pls notify me for this solution
Feb 14, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Logitech Harmony 520 LCD Remote Control Logo
54 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
