Question about Konica Minolta PagePro 1350W Laser Printer
Deskpro 1350W will not pick up paper
Do you have a picture of how the paper base/tray sits in the unit. It was out when I received the unit. The white geared-wheels on either side of the tray spin it looks like they should lift the paper up to the paper-pickup wheel (rubber ribbed), but they doen't. The wheels rotate through their cycle without touching the tray.
  • LannieC Mar 28, 2008
    The problem is not the rubber pad that picks up the paper. The paper tray is not lifted high enough to engage the rubber pad.
  • Anonymous Mar 27, 2014
    won't pick up paper
  • Konica Minolta Master
  • 19,396 Answers
Try to see if there is dirt, dust or some object obsctructing the tractors
Posted on Mar 28, 2008
  • 1 more comment
  • Ginko
    Ginko Mar 28, 2008
    The mechanics may be stuck try gently pushing the rubber wheels on the paper.
    If the above does not work the mechanics of the tractors may be broken. You will need to disassemble part of the machine and assemble it back. You may find out that some part is missing or out of place . Other solution is taking the printer to service.
    If you decide to do the job yourself you will need the service manual. Here is the download . The manual is in compressed format , you will need to install WinRAR to unzip it.
    Regards
  • Ginko
    Ginko Mar 28, 2008
    Try to play with the mechanic that lift the paper , pull it up very gently. If it does not unlock probably some part is broken or missing. You will need to follow the exploded view in service manual and check it out.
  • Ginko
    Ginko Mar 28, 2008
    Also unplug the printer and turn it upside down, try to hear if there is any object moving inside the printer , or to see if any object comes out. a broken part or a small foreign object inside the printer can block the mechanics.
White streaks on every printout
Pull all imaging units out and clean the laser with the wand provided either in tray or on front door.
Sep 07, 2017 | Konica Minolta PagePro 1350W Laser Printer
Will not pick up from paper tray
Your probably need to replace the rollers in the paper feed unit for that tray, try cleaning them with alcohol
Mar 24, 2010 | Panasonic Workio DP6030H Black and White...
Hello, The printer (roller) is not grabbing the paper to print. I am on hold for at least 20 minutes and my minutes are wasting away..Help! What can I do get it to print without a problem. Thanks MS
Check the paper to see if you have too much in the paper tray or if any of the edges are frayed. I've also heard that it may be related to a issue on the roller that picks up the paper - I have that problem myself. I was told to check the roller and if it's dirty clean the roller with some rubbing alcohol.
Jan 27, 2010 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Faulty paper pick-up & tracks down the length of the paper
This problem is caused by a slippery paper pick-up roller. Because the paper slips, it "arrives" too late in the printer mechanism resulting in image shift or paper jam.
You can see this gray rubber roller by removing the paper tray and the imaging unit and turn the printer on his back. Sometimes it helps to "clean" the roller with some sandpaper (take care to remove all small particles!) and/or clean it with some liquid (white spirit, thinner etc.)
Adri Hankel
Aug 07, 2008 | Samsung CLP 300 Laser Printer
Won't pick up the next sheet of paper
While it doesn't always work, this problem seems to be helped by keeping the tray as full as possible. It has more trouble picking up pages when the stack is low.
Aug 04, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica 1350w will not pick -up paper any more? please help?
I had the same problem. I noticed there is a ridged rubber wheel that picks up the paper and it was just sliding over the paper. I opened the printer, pulled the toner cartridge out and rubbed the wheel with my finger until I could feel friction. Closed it back up and it works. Perhaps the rubber wheel gets coated with paper fiber and makes it less "sticky" over time. A simple cleaning may be all it needs.
Jul 27, 2008 | Konica Minolta PagePro 1350W Laser Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Not noticing paper
I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
Dec 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
76 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
