Question about Sony KP-46WT510 46" Rear Projection HDTV
TV will only work every other day. On the days
TV will only work every other day. On the days that it does not work, the red light blinks for about 20sec and turns the set off. On the other days, the red light blinks for a couple of seconds, and then the picture comes up. What is wrong with the set?
  • Sony Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Posted on May 10, 2010
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
My tv will not turn on the red light turns blue then back to red
Check for bad capacitors in power supply for your inverter circuit.
Nov 19, 2011 | Televison & Video
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
No picture just a standby red light flashing
tv won't turn on red blinks 5 times , some times it will turn on like every 3o04 days
Aug 06, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV will not turn on instead of blue light get blinking red light
I called Best Buy and they had a record that I had bought the extended warrenty and will be out to fix the TV in a few days. I could not remember that I had bought the warrenty.
Dec 25, 2008 | Televison & Video
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
