Question about Kitchen Ranges
I have a new proline pool pump and filter, it turns on and runs for a minute than stop, after about 5 or 10 minutes it will star again and do the same thing. I checked the voltage at the plug and its reading 240 volts. this is a new pump and pool whats wrong?
  • 6 more comments
  • newstar1 May 10, 2010
    That was one of the first things I checked thanks anyway
    I was hoping i could find a simple fix myself its an 1+hr ride to the pool place.
    what do I need to look for in the wireing? the pump came pre wired and I have not changed anything, do you think it could have something to do with the grounding?
    I have a new proline pool pump that i just installed with my new pool. when I plug it in it runs for a minute or two then stops. it will restart after 5-10 minutes. I tested the plug and got 240 volts. I have checked for obstructions in the lines etc. I was hopeing this is something i can easly fix myself as uts an hour + to the place I bought it. I have not changed any of the wireing on the pump.
    Do you mean the wires from the breaker panal to the outlet?
    It has a dedicated line from the breaker panal to its own outlet that the pump is pluged into
    also I used 12/2 wire and the run is about 60 feet
    did i say 12/2 wire i ment to say 12/3, yes there is plenty of circulation. tomorrow i will check to see if it mite be cavatating thanks to all
  • 6,927 Answers
Check the wiring to the pump motor,if they are too small,it will shut down
Posted on May 10, 2010
  • 3 more comments
  • Ronny Bennett Sr.
    Ronny Bennett Sr. May 10, 2010
    Yes,how is it wired?Is it plugged into a outlet ,or is there an extention cord?If it is plugged in directly to an outlet,then this most likely is not the problem,but if the pump motor is not getting any air,it would cause this to happen also.
  • Ronny Bennett Sr.
    While the pump is running ,feel with your fingers,of the breaker,see if it is getting warm
  • Ronny Bennett Sr.
    Again,feel of the wires you ran,see if they are getting warm to almost hot.
  • Ronny Bennett Sr.
    You used 12/2 only two wires?If so,you need to run a ground,
  • Ronny Bennett Sr.
    What did you come up with?If the pump is getting enough air for cooling,and the wires ,or braker is not the problem,replace the pump,it will be defective
    Guru:
  • 312 Answers
If it is new just go back to where you bought it. It must be under warranty. Even if there was no warranty most states have a buyer protection law which would be under your State Attorney General's office. Good luck this should be easy to solve. Darrell S
  • Darrell Sorenson May 10, 2010
    I sound like a broken record? I would at least call the dealer where you purchased the pump to get advise. If you have a bad wire kit get another one, let the dealer do the work for you. That is what I would do to save you some time and frustration because it is not working.
  • 10,865 Answers
Most motors will shut off automatically if they begin to overheat. If this is the case, check the inside of the pool trap to see if any debris has worked its way past the basket and into the opening at the impeller. Turn all the valves to the off position to prevent the water from draining out of the trap. Otherwise, you'll have to re-prime the pump. Remove the trap lid and empty the basket. Feel around for any twigs that may be stuck in the opening. Put basket back in and trap lid back on. Turn the switch back on. If this does not solve the problem I recommend calling the pool company where you got this equipment. Have them check it for you as you may have a bad pump. Joe
Intex sand filter problem
It sounds like a pump issue, not the filter. When a pump motor runs for a few minutes and then cuts off, that is usually a thermal switch shutting down the motor to keep it from overheating and causing trouble. This typically is caused by a bad winding or some kind of short that is internal to the motor.
Usually the fix is to replace the motor, but you may want to have a pool guy out to verify that. Good luck with it!
Jul 03, 2013 | Pool & Spa
Engine stars and then stops, not fuel pump problem
What is the make/model/year/motor etc.?
Sep 15, 2012 | Cars & Trucks
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Pump motor not operating
The pump is defective and will need to be repalced.
May 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
Anthony filter system faulters after short while of running
If you have alge in your water it builds up in the filter and stopps it up rite away. You will need to take the filter apart again and hand clean it out again. but you will need to super chlorinate the water and kill all the alge before you start the pump or it will plug again. If you run it like this for any amount of time it will crush the grids, so be sure you kill all the alge.
Oct 13, 2009 | A.B.S ALADDIN GO-KIT #7 ANTHONY POOLS 2"...
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Kitchen Ranges Logo
348 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
