Question about Panasonic PT-AE700E Projector Lamp
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does it have anything to do with the problem
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
Posted on Jul 07, 2010
  • jpoon321 Dec 09, 2010
    Where can I source a blue optical block for the AE700? I am in need of one but can't seem to find a place to buy them.
  • bbspills Dec 09, 2010
    It's not just the blue part, you actually need to replace the entire optical block which has the blue part attached to it. It's a fairly easy replacement. I have a 100% working optical block if you are interested as replacing them from panasonic makes no sense as they cost $600. Email me at BBSpills@gmail.com if you would be interested.
  • Panasonic Master
  • 12,061 Answers
WHAT IS THROW RANGE ?
8ft to 40.6 foot throw distance. Screen size is 40-400 inches.
Jul 10, 2014 | Panasonic PT-AE700E Projector Lamp
Where can i get an optical block for a panasonic PT-AE700E and roughly how much am i looking at
USD150 for the Optical block for AE700
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 04, 2013 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
How to reset panasonic projector ae700
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
have a nice day!
Aug 01, 2012 | Panasonic PT-AE700E Projector Lamp
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
How far to mount projector from screen, screen is a lp morgan rondo
It depends on a lot of factors -- how bright the area is going to be, the size of your screen, etc -- but you'll be roughly 9 to 14 feet from the screen for most settings.
I'm basing this on numbers for a PT-AE700U projector, as I wasn't able to find the AE700E.
Take a look at the ProjectorCentral.com projection calculator if you want to get precise about the distance for your environment.
But be sure to rate my fix as "Helpful" before you click that link! :)
Aug 17, 2009 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700E Projector Lamp Logo
901 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
