Question about Panasonic Televison & Video
The picture on my TV has a purple arced curve across the bottom and top of the screen. I've adjusted the colour which didn't correct the problem? I have a PT-47W33G 47 in rear projection
  • 2 more comments
  • glenp11 May 10, 2010
    the first picture is what ours looks like, I did go to the set up meny and adjusted according to the instructions there. Centering the green line and adjusting the blue and red colours. This improved it a bit, but theres still an arc across the bottom _purple with a green haze above it, sometimes black), as well as distorted along the top, and the picture is a bit fuzzy.
    I'm still working with this tech, he's determined the problem, I've confirmed his determination is correct, now I'm waiting for repair instructions.
    Is there somewhere else outside of EBay I can purchase the Convergence Chips at, possibly an electronics supply store of some sort?
    Thank You
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
It sounds like a convergence problem.
I will attach a few photos of what this looks like, no two sets will look exactly the same but you should know if it is what you have.
If it is I have start to finish, step by step instructions for this repair in this type and brand of set.
They tell you everything you will need and how to do the repair yourself. If you have even moderate skills this can be a do it yourself repair. Total parts cost if purchased on EBAY can be under 30 dollars total.
Let me know and I can post the instructions here for you to copy/paste and use.
SD TECH
Posted on May 10, 2010
  • 3 more comments
  • SD Tech
    SD Tech May 10, 2010
    Just so you know, I have repaired hundreds of these sets with this problem.
    This model uses two STK-392-110 CONVERGENCE CHIPS AND both will have to be replaced and the set adjusted.
    My instructions show how to do all this.
    SD TECH
  • SD Tech
    I will post the instructions now in several parts---ignore some of the true false junk as the document was composed in MS word.
    What you will need;
    Two new STK-392-110 convergence Ic’s
    Solder
    Liquid solder flux
    Desoldering braid or wick
    A good soldering Iron
    Some denatured alcohol
    A small toothbrush
    A Philips screwdriver or screw gun to REMOVE SCREWS
    A PAIR OF GLOVES
    1.) UNPLUG TV SET.
    2.) Remove back cover of TV set.
    3.) Remove entire front speaker grill on set(it pulls off and may resist being removed)
    4.) Locate and unplug speaker wires (they are plugged into the main circuit board).
    5.) Locate three cables with wires that come from the Front keyboard—two of them have to be unplugged from the main board(all plugs are different sizes but note where they go)
    6.) Remove 2 long philips silver machine bolts from the front of the set (behind the grill).
    7.) Remove 4 more in the back of the set; two are located at the extreme back edge of the plastic frame and hold the chassis down; two more are located on either side and also go straight down; note which are which and set them aside.
    8.) Using gloves pull the entire metal box (it is called a light box) out of the set; there are hand holds on either side—careful as the metal has sharp edges.
    9.) Remove the box from the set and locate the two Convergence IC chips; they are located on identical metal heat sinks with fins and they should have the STK-392-110 number clearly printed on them in white (they are black)
    10.) Turn the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid for this—get all the pins completely de-soldered.
  • SD Tech
    11.) Inspect the dozen or so light blue resistors in front of them; most are marked 2.2 ohms—if any are white in the middle you will need to replace them at the same time; best way is to check all of them like checking a fuse----they protect the set if one of the STK’s shorts in any way.
    12.) With the STK’s completely unsoldered turn the box upright and remove the two screws on each IC. If the chips have never been replaced you will need to tap them loose with a putty knife or flat bladed screwdriver.
    13.) Remove both IC’s.
    14.) Apply heat sink grease to the two new IC’s and install them one at a time; this part can take some time and it is important the pins on the new IC’s are perfectly straight---once you get them in, Hand tighten both the screws on each IC---do not use a screw gun—you can strip the screw holes out. Clean the bottom of the circuit board where the chips were soldered with some denatured alcohol and apply liquid solder flux to all the pins.
    15.) Presuming you have already found/replaced any bad resistors turn the box back over and solder carefully both of the two new IC’s in, --do not short any of the pins to each other when you do this and when you are done it is a good idea to take a close look at both to make sure all pins are soldered and not touching each other with soldering you have just done. I suggest you do clean the pins on the bottom of the circuit board again with denatured alcohol.
    16.) Slide entire light box back into the cabinet.
    17.) Reconnect the plugs you removed when you removed the box. At this point take a lens cloth or a paper towel with glass cleaner sprayed on it and clean the three large black lens-if they are dusty the picture will be darker and not as clear as is should.
    18.) Position the box so it is all the way in place and none of the wires or plugs are pinched.
    I usually at this point turn the set on before I replace the Six bolts that hold it in—2 from the front and the four in back----this way if you have a problem you can remove the box faster.
    19.) If the set comes on and now has normal Convergence go into the customer menu and adjust the convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set usually offers is a green cross in the middle of the screen—do not adjust Green!
  • SD Tech
    20.) Once you have the Red and Blue in the center adjusted find the second convergence mode---it will give you 8 or nine points on the screen with instructions on how to change from blue to red---use the original remote with the thumb wheel or cursor buttons to adjust.
    21.) NOTE: SOME of these sets need to have the Convergence adjusted in first: full/4:3 and second in the other two zoom/wide zoom and third on the HD input with a HD signal coming in. There is also an option at this point to go into the Technical menu and fine adjust the convergence all over the screen—if you need this I can give you instructions based on the model you have—most of the time adjusting the set in the customer mode will produce a good result.
    22.) I know all this may seem complicated to you, but this repair should take about an hour or so and just take your time when you get to adjusting the set.
    23.) If all looks good turn the set off and Unplug it; install all 6 of the chassis bolts back; replace the back cover and the Speaker grill and plug the set back in.
    24.) You may find it useful to go over the convergence Adjust again—to get all the points as good as you can. There is a hidden Tech menu that will allow a finer adjustment of the entire screen----it is somewhat difficult to access and there are a lot of buttons on the remote that then do different things.
    Most of the time adjusting in the customer menu will give you a very acceptable picture.
    This completes the instructions. SD TECH
  • SD Tech
    Sure but on Ebay from a seller I know you can get two of them for less than 12 dollars and most of the local places here get over 20 each for them.
    The seller is a company in Maryland and ships fast (Suburban Electronics) on EBAY select advanced search and search by seller------------ sewsales55 is the one I use and they also carry most of the other needed items.
    SD TECH
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Do not have copy of owners manuals and user guides
Problem is likely with a setting at the picture source. Make sure you only have enabled the setting your TV is capable of (480i, 480p, 1080i, etc)
Apr 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Colour problems on TV
try to disgusting it and next time don't near it the magnet or speaker
Sep 25, 2009 | Televison & Video
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Color problems??
There doesn't happen to be a speaker nearby does there? I've seen this a lot with center channel surround sound speakers. It goes like this because of the magnet in the speaker. Try moving the speaker if there was one (or anything else near the TV that may have a magnetic field). Then, every time after you turn your tv on it should get slightly better thanks to the built-in degaussing coil in your tv. If not, find a TV/Appliance repair man near you, and he will have what's called a De-gausser and will probably charge around $30 to use it on your tv. You'll be watching 2D TV again in no-time!! ;-)
Jun 05, 2009 | Hitachi 43FDX01B TV
Sony kp53hs30 screen is curved at top/bottom when in widescreen
on the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
