Question about Millett Buck Silver Rifle Scope 3-9X 40 Medium Plex Matte
Millet 3x9 scope magnification ring is stuck.
Older Millet 3x9 scope. The magnification ring is stuck. Does any body have any ideas?
Took my Pentax 4-12X 40mm rifle scope mounted on a Remmington 7mm mag bolt action rifle to hunt antelope in Namibia, SW Africa. First shot on a fine kudo blew up his heart and broke off-side leg bone....
you got it in one there,,,its all down to "head butting the scope"!
your head **** has pushed the eye bell up the scope body and has pinched or locked the power adjuster ring to the scope body
you have only two choices send the scope off for repair,,or buy a new scope,,,done even think about trying to fix it as you cant,,
it will need a strip down and then a re-gas (to stop it foging up)
so if you took it to bits the scope would be distroyed
Aug 22, 2010 | Pentax Optics
3-9x40 magnification ring just spins
Without seeing the scope, I can only guess, the zoom ring has lost it's screw, The rear lens will come off easy enough, then peek inside for a loose screw, if you find it, you will see a long twisted slide on the side of the tube just inside, turn it till you can see where the screw went. It should be a set up something like that. when you turn the zoom knob it slides a lens front to rear fast, and it rides on that screw, Check it out.
Jul 14, 2010 | Simmons 511072 3-9x32 A/O 22 MAG...
I have lost the screw cap on my Tasco scope 3x9,
Call (800) 423.3537 and ask them, TASCO, caps should be common thread sizes. Otherwise, Midway or someone like that may have replacement caps.
Jun 02, 2010 | Tasco ® Silver Antler® 3-9x40 mm Scope...
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
Feb 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Weatherby scope 3x9 when i turn the power ring the cross hairs turn and the vertical cross hair ajustment dosn't turn
im sorry to tell you that this scope has fell apart inside if its worth fixing its going to cost more that a new scope would do and if you take it apart to try to fix it yourself you will need to refill it with gas to stop it foging up when it gets cold, best this to do it go onto e-bay and get a new scope
Dec 30, 2009 | Optics
I have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Nov 14, 2009 | Redfield See Thru Rifle Scope Mount Base...
On scope adjustment my older weaver 3x9 micro trac dosent have clicks just marks on the dial how much change in 1 mark movementscope is about 20 years old
Most of the older type scopes were rated at 4 clicks per inch at 100 meters.But to be sure you will have to test it. I generally do that at a 50 meter range and then it is 4 clicks per half inch.
Oct 11, 2009 | Weaver Rifle Scopes Grand Slam Silver...
Overtighten causes hazing,and adjusment problem
As a general rule of thumb, If you have normal Weaver-type aluminum rings, you tighten to 10 to 15 inch-pounds. If you have normal Weaver-type steel scope rings, you tighten to 15 to 20 inch-pounds. If it's something exotic and/or expensive, you're pretty much stuck contacting the manufacturer. Leupold Mark 4's require 65 in-lb, for instance.
Wiha makes two adjustable torque screwdrivers (one for lower torque, and one for up to 60 in-lb that are perfect for most any scope ring applications.
May 04, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
Remounting a rifle scope, Luepold 3X9 with Luepold rings
hey jerry when ya renount a scope ya just want to tighten all the screws evenly when ya do this ya want to start with right front then left rear then left front right rear you do this till its as tight as you can make them without striping screws when your done you should have even space at all the rings good luck and i hope this helped ya
Oct 30, 2008 | Leupold ® Rifleman® 3-9x50 mm Scope
Millett Buck Silver Rifle Scope 3-9X 40 Medium Plex Matte Logo
472 people viewed this question
Top Millett Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Millett Optic Expert? Answer questions, earn points and help others
