Question about Garden
Cannot get pool pump to prime
Jandy pump, was working well and had storm that put in much debris and clogged intakes and skimmer. cleared up, emptied filters/skimmer and pool pump will not restart completely, it just flows very little water and does not get full suction. skimmer does not get any suction.
  • Michael Guadagno May 10, 2010
    tried to flood the pump, but still trickle of water.
  • 198 Answers
Turn the valve to main intake line (not the skimmer) and flood the pump with as much water as possible.
make sure there are no areas around the seals where air could get sucked in. when you get a full flow switch it to skimmer and main.
Posted on May 10, 2010
How to clean debris from impeller? Pump is not drawing water from the skimmer/pool .... I'm hoping the impeller is clogged and not something more serious like a shot motor.
There are normally 4 to 6 bolts around the outside connecting the wet end from the dry end. Undo those bolts and the front of pump should come away. Then you should be able to see impeller. Using a piece of wire poke it through each slot of the impeller to clear the blockage. Then put back together again. Remember to prime the pump
Jan 30, 2017 | Pool & Spa
My swimming pool pump is loosing it's prime
is there enough water in pool sometimes skimmers suck air also check the intake union of the pump you have a leak in one of your intake lines
Jul 12, 2014 | Pool & Spa
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
Pool pump motor runs but doesn't circulate the water
make sure the pump has been primed, all the valves are open and in the correct position, no obstruction in the skimmer.
if the pump is working but water still not circulating, the impeller may be clogged with debris. you will need to split the pump and use a shop vac to remove the crud in impeller fins.
Sep 25, 2013 | Hayward Pool & Spa
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
Our intex pool pump has no suction.
Start by checking all the clamps on the hoses at pump and at Skimmer, and tighten. Next, see if there is any visible cracks in suction hose and replace if cracked or leaking. Next, if that doesnt fix, loosen clamp and remove hose from front of pump and look inside to see if any debri is clogging the impeller, if so you can use a screwdriver to clean out. and last, make sure skimmer basket is empty and not packed with leaves and debri.
Aug 31, 2011 | Intex Pool & Spa
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
How do I relieve the pressure on the pump
Make sure that the skimmer and pump baskets are clear of debris. If they are full, an obstruction can cause pressure to build up. You might also want to re-prime the pump to relieve the pressure. Make sure that your impeller is clear of debris. All of these problems can cause pressure build up in pool pumps.
Jun 18, 2010 | Pentair Superflo 1 Hp In Ground Pool Pump
I have a Pentair Intelliflo pump system and lately it won't kick on to filter pool. It starts to prime and it won't create enough pressure on gauge to hit the threshold. It will get close and then it...
Your pipe could be clogged or you may have a clog in the impeller. Check the pump basket and if it is cracked then it is probally in the impeller and you may be able to reach it with a screwdriver and needlenose. If you have a crack in the skimmer basket it could be in the line and you can check this by putting a kitchen sponge in the skimmer and if it comes out in the pump the line is clear. If it is clogged you may be able to clear it with a flush bag you can get at any hardware store. If that dosn't do it you will need to get a pro. Good luck.
Dec 28, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
