Question about Zenith DVB412 DVD Player
Parental screen coming up on a DVD. Not able to watch DVD.
I just rented the dvd "Across the Universe". IT's new. When i put the dvd with the film on it in the dvd player, I get a parental control screen that I can't get past. I can't watch the film. The feature dvd that came with it, works fine! Everything I have works fine. What's the deal? I have a GoVideo and have never had any problems with it.
Same problem.   I try to load the "Across the Universe" DVD and get a parental control screen I can't get past.  Only "Across the Universe" seems to do this.
  • Anonymous Jun 08, 2008
    same problem-blockbuster dvd
It needs a code-I played with it, till I figured it was 4444
Posted on Nov 26, 2011
Same problem. Same DVD. Just rented it from my video store and I'm so frustrated. My video store said it's the DVD player. My special features DVD also works, but I can't see the main movie!
Posted on Jun 29, 2008
I have the same problem, clearly Netflix's "Across the Universe" is the connecting factor.....
Posted on May 11, 2008
I have the same problem! did you find a solution to this?
Posted on Mar 30, 2008
I am having the exact same problem. Across the Universe rented from Netflix. I contacted Netflix and they said it was not the DVD but the DVD player. Does anyone have a solution?
Posted on Apr 01, 2008
2 Suggested Answers
SOURCE: Parental screen coming up on a DVD. Not able to watch DVD.
use password 3308 to change the parental control to 7, and the movie will run
Posted on Feb 17, 2008
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
DVD will not let me select language
You have to press triangle on the remote control and the menu will come up.
Jan 14, 2009 | Sony PlayStation 2 (PS2) Console
DVD/Across the Universe/Won't play
Here's what I did, which WORKED!
On your DVD player (with the disk out of the player), add parental control at level 7. This WORKED!
Aug 08, 2008 | Sharp 25VS-J250 25" TV
PLEASE HELP, PARENTAL LOCK CODE ESA DVD/VCR COMBO UNIT
this is a new thing on dvds. must reset.
Feb 25, 2008 | Televison & Video
Zenith dvb410 parental control
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
Feb 15, 2008 | Televison & Video
Feb 14, 2008 | GoVideo DV2150 DVD Player/VCR
I just rented a new dvd from Blockbuster and I get a parental screen that comes up. I can't get past it and can't watch the movie. All my other movies work fine. Even the feature dvd that came with the...
You have the rating set on your DVD player to lower than the rating of the movie you are trying to watch.
Somewhere in your setup menu of your DVD player (press the "setup" button on the remote with disc stopped or no disc) you will find a place to set the parental lock. Either turn it off, if that is an option, or set it to the rating of the movie (or higher) to enable viewing.
Feb 14, 2008 | Televison & Video
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Zenith DVB412 DVD Player Logo
198 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
