An area of cooling fins about the size of my hand has rotted away on my compressor. what kind of problems could that cause?
  • Brian Niten May 11, 2010
    On your compressor or on the condenser coil?
The fins are on the coil.
Posted on May 10, 2010
    Novelist:
    Champion:
  • 246 Answers
The 'fins' you are talking about are actually on one of the coils and since you said 'cooling fins' I'm assuming you are talking about your evaporative coil. The fins are designed to help air movement across the coil and if a part of them are missing (the size of your hand) then that could cause an un-equal distribution of air across your cooling coil - which could cause the unit to not cool as well as it should.
Short term - The unit would still produce cold/cool air but would not be as effienct as it should be.
Long term - it could affect the compressor in a negative way and shorten it's life.
I would have a Service Tech take a look at this - it may be that you will need to think about buying a new unit.
good luck!
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
Car running hot
Check the radiator fins to see if they are rusted out and not carrying away heat. Fins rotted out usually cause heating problems at higher speeds.
Jun 05, 2011 | 1994 Ford Taurus
Runs good when cool outside but runs rough when weather warms and gets hot ,its a 350 chevy motor
check the fins in the rad...i had a van & the fins rotted away...caused her to run hot
Oct 10, 2010 | 1985 Chevrolet Chevy
Maytag 2003 Model # MSD2754GRW does not get cold anymore. Both sides are warm. Cleaned underneath to remove all dust.Still runs warm.
Need you to pull away from wall, unplug and remove cover over compressor area. Put your hand on top of the compressor and feel for heat. Tell me if too hot to keep hand there warm or cool. That will tell me a lot. I will know by your answers whick way to go with this.Sea Breeze
Mar 22, 2010 | Refrigerators
Not blowing cold air
Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
Aug 15, 2009 | Heating & Cooling
Our air conditioner always ices up.
3 things will cause this. Trying to cool too large an area for the size of the unit, trying to cool an area too fast & dirty fins. Match the BTU's to the square footace (based on an 8' ceiling), Run it on low speed most of the time. Keep it on, even when not using it, if you will use it daily. Shut off the unit and spray the fins with Windex and then spray with plain water to rinse.
Jul 22, 2009 | Haier hwr10xc6 Air Conditioner
Everything is still running but it doesn't get cold
  • Is the thermostat knob turned to the proper setting?
  • Is the compressor motor running? It's a football-sized case with no apparent moving parts on the outside of the freezer at the back near the bottom. Is it humming or making any kind of continuous noise? If it is, but your freezer is still not cooling at all, there may be a serious problem with one or more of these areas:
    • The compressor
    • The condenser
    • The evaporator
    You can't service these yourself. You need to contact a qualified appliance repair technician.
    If the compressor isn't running but you do have power to the freezer, there may be a problem in one or more of these areas:
    • The compressor
    • The overload and relay
    • The defrost timer
  • Jul 16, 2009 | Freezers
    No cold air.
    Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
    • Compressor
    • Condenser
    • Evaporator
    • Compressor
    • Burnt wiring
    • Capacitor
    May 26, 2009 | Fedders A7D18E7B Thru-Wall/Window Air...
    Hot to touch
    there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
    Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
    DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
    This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
    Nov 05, 2008 | Frigidaire Refrigerators
    Heating & Cooling Logo
    52 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
