Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
WILL IT SUPPORT THE MacBook pro
Will the D-link 624 support the MacBook pro ? I can see the SSID ,but can't connect,it tells me that it timed out.
    Guru:
  • 825 Answers
Dear friend try to add a $ symbol before the network key and click connect...it may work...
i think the security type which you have enabled now in router is WPA... you need to change the security type to 64bitWEP on your router, and try connecting again....
to configure your router you can follow the steps given for Belkin router, by clicking here... All the routers will have similar kind of configuration.... only the user interface will differ...
first check for the default gateway address of your router.... you need to enter that address in place of BELKIN default ip address given in that link....
Posted on May 10, 2010
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Hi, I'm trying to reconfigure my Solve Your D-Link AirPlus Xtreme G DI-624 Wireless Router, but I simply can't connect with it trying the following IP (Both with cable and wifi; the router SSID can be...
You will need to be hard wired (you can't configure a router via a wireless connection...
For default IP use 192.168.0.1 and the default user name is "user" password is .
that should get you in.
Mar 07, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Okay my names shane and i am trying to hook up my ps3 and i have a d-link wireless router and i dont know what the ssid is and i cant find it anywhere and i was wondering if there was any way you could...
If I understood it correctly, you need to broadcast your SSID from your router (alternatively, you want only to know your SSID; in both cases, go to your router configuration). There's an option to do that, simply go to the router address at http://192.168.0.1 from your computer. You'll be prompted to enter the user (which is "admin"); leave the passed field blank (unless someone else have configured it differently).
Hope it helps!
Jan 13, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Trying to find the key to connect my wireless computer & printer?
The SSID key is usually located underneath your wireless modem
look on the bottom of your modem and located the ssid key this is usually what your looking for.write this down and type it in
Oct 04, 2010 | Apple MacBook Pro Laptop Computer with...
I can not figure how to change the name of my wireless connection how do i do so?
Hi, this is simple the name of the wifi connection is the SSID, you need to login to your router via a web browser, entering default, (Assuming it hasn't been changed, if so you need to press reset button at rear of unit to restore default,) login and password, and when you are IN the router, you go to the SSID section and make it anything you want, it doesn't matter.
Please go to this link below and download your user manual, it will show you how to login to the router, using default passwords, it also will show you how to change the SSID, (Or name of the WiFi Connection)
http://www.dlink.com/products/?pid=6
Sep 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hi. I have a DI-624 wireless router, using it for one desktop and two laptops. It used to work very well as a wireless router. But recently I shifted its physical location, after which the signal falls out...
Any chance there is another router with the same SSID nearby?
Perhaps when your router is dropping off the workstation is finding a different router with the same SSID.
Sep 15, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
After turning the radio signal off in the D-Link 624, it doesn't allow connectivity. Makes sense, but how do I get back in to turn the radio back on?
There's an online manual:
manual
The login to the router is: http://192.168.0.1 (factory default login):
User name is: admin
Password: [leave blank]
In case the password has been changed earlier you'll have to perform a default reset by pushing the reset button with a e.g. paperclip on the rear side for 10 seconds and then releasing it: After this the router will reboot to the default factory settings.
Check "Broadcast SSID" = radio signal:
See page 29: in the router select Advanced > Performance:
SSID Broadcast should be enabled: Apply to have settings saved.
Check broadcast SSID name and WEP security access:
See page 13: in the router select Home > Wireless.
Sep 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant connect my xbox wireles to my dlink
reset the wireless settings of the router, the connect to the ssid of the router then
Aug 15, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Connecting d-link di-624 router with ipod touch
I configured my D-Link router, choosing an SSID, and a password for all wireless connections.
I configured my iPod Touch to connect to that SSID, and specified the password, and it works fine.
So, it works for me, and it can work for you.
Apr 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DIR 655- losing connection with ntwk is "INVISIBLE"
unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
Dec 11, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
