Question about Philips 42PF7320A 42 in. Plasma HDTV
Philips 42pf7320g/79 plasma have no picture or sound but everything els seems to work remote and green and red lights tv even makes click sound when turn on but still no picture or sound plz plz help as im along way from city 2 hr drive to get fixed
mumma_1
  • 903 Answers
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
Posted on Jun 25, 2009
  • 1039 Answers
SOURCE: I have a philips 42PF7320G/79 ,has a problem
Replace swolen capacitors on the power board.
Posted on Sep 19, 2009
SOURCE: Sound but no picture Philips 42PFL9632D/79
I had the same problem, no picture, contacted Philips who put me on to NESN (0845 610 4105) for local agent, they diognosed a falty "Inverter Board" all costs will be £365as the set is only 18 months old Philips are looking into some compensation towards the costs. I await there reply. Looking at several web sites worldwide this seems to be a problem with this set between 12 & 24 months old.
Posted on Jan 17, 2010
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
My power comes on, then the green LED light switches to red, and flashes 6 times over and over. I tried the fix on youtube with the IC capacitors for the 50PF9731D/37 even ordered the $1 capacitors but...
I am definitely a girl explaining this because I don't know the correct parts of the tv. Here goes. We had the same problem last year, called philips they advised I do a software update on the tv because that fixes everything....wrong. The light still flashed and no picture. I called them back and they said I had to find a philips tv repair to take it into....got lucky because there was one close by. Come to find out it was some board inside that cost $400 to repair. I thought cool it's cheaper than a new tv! Worked great until about 2 weeks ago the tv turns on and the light is green and picture pops up a minute later. Oh boy more problems! As I sit here right now my tv no longer has a picture. The green light is on but nothing. It's funny because we had it repaired this time last year. I'm fed up and buying a new tv!
Nov 29, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
We have a Philips 4 BDS4231R/00 and it does not start. We can here the relay sound and if we turn it on and off say 7 - 10 times it works fine. Could anybody tell me how this can be fixed. Please
Hey John, I am experiencing a very similar problem. If I unplug the TV when it is on (green light) and plug it back in. It begins green, and clicks to red. I immediately turn the TV back on with the remote. Most of the time it seems to struggle for several seconds, sometimes with a little scratchy audio popping in and out. It will then go from green to red on the TV and if I try to turn it back on it will go green for a few seconds and back to red but without any click coming from the TV. No matter how many times I try after that, no TV. If, on the other hand, I unplug while green, plug it back in and with the remote turn it back on after it has come up green and then clicked to red, it will come on. It might take thee or five times but at least it comes on... If you hear of a real solution, please let me know (bennettkw@hotmail.com) in the meantime, best of luck.
Dec 28, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
