Question about Astra Home Grinder Electric
I bort a 2.2 astra sri mk4 an was told that the valve had dropt bt ther is no problem with the valves so im lost in why it will not start ?
I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine? Suggestions on what it could be?
Tags location of knock sensor
https://outofthebooks.top/term/location-of-knock-sensor
Need to locate knock sensor on 1999 camry V6. Where is ... Cabin filter · I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine?
Common problems with the Astra G [Archive] - Astra Owners Network ...
www.astraownersnetwork.co.uk > ... > Astra Chat > Astra G
Mar 20, 2007 - 100+ posts - ‎100+ authors
Also, rear disc brakes on the SRi models have a tendancy to seize up ... Pre 2003 2.2i.... about 10mins but the engine temperature stays fine when running. it .... theengine manigement light is constantly on, but car running like a dream! ..... I have a 2007 astra sport hatch sxi 1.6 and seem to have a strange ...
Holden Astra known issues? - Holden - Automotive - Whirlpool
forums.whirlpool.net.au > Automotive > Holden
WhirlpoolDec 12, 2012 - The TS Holden Astras, late 90s to early 2000s, stay away. Unreliable ...People give the TS Astra a lot of flak but its a superb car. We have one ...
Jan 20, 2016 | Cars & Trucks
Astra sri
do the diagnostics probably there is some fault in the engine system
Apr 16, 2014 | 2006 Opel Astra 1.8
Problems diesel starting
check thtat the glow plugs are actually working ( relay or fuse probnlem)
check the pressure valve that holds line pressure to the injectors
have the injectors overhauled because if just one leaks down the residual pressure is lost
May 12, 2017 | Cars & Trucks
97 GMC YUKON 5.7 4X4, HAS A PO785 CODE......WHEN FIRST STARTED IT SHIFTS AS IT SHOULD. BUT AFTER ITS WARMED UP AND I STOP AT A STOP SIGN I COMPLETELY LOSE OVERDRIVE AND IT WON'T DOWN SHIFT. I HAVE TO...
HERE WE ARE AGAIN STILL SAME ISSUES AFTER CHANGING ALL 5 SOLENOIDS,FLUID,FILTER AND EVEN THE INTERNAL WIRING HARNESS IN 4L60 TRANSMISSION IN A 97 YUKON. STILL GETTING A P0785 CODE. WHEN 1ST STARTED SHIFT PERFECT TILL IT WARMED UP AND I MAKE A COMPLETE STOP. THEN IT WON'T DOWN SHIFT AT ALL AND I HAVE NO OVERDRIVE. HAVE NEVER HAD ANY PROBLEMS WITH TRANS TILL IT STARTED DOING THIS OUT OF THE BLUE. NO SLIPPAGE NO BURNT FLUID EITHER. I'M TOTALLY LOST AND DON'T WHAT ELSE TO DO. CAN ANYONE PLEASE POINT ME IN THE RIGHT DIRECTION? PLEASE EMAIL imhausen72@gmail.com
Sep 25, 2013 | 1997 GMC Jimmy
Astra G MK4 Radiator Fan working overtime - HELP!!
Probably need to replace the fan. Like anything else they do were out. Just check the mounting points are tight 1st incase its just a loose bolt or clip.
Jul 16, 2012 | Vauxhall Astra Cars & Trucks
Code P1259 what would cause this?
P1259 is the code for the VTEC pressure switch.
1. Check your oil level first, if oil level is low the code will come on. Add oil and reset the light.
2.you might have a bad Vtec oil pressure switch, try replacing it.
Jun 26, 2011 | 1998 Honda Accord
I have a Holden Astra 2001 with the emissions engine light on, the manual states that its OK to drive however if if starts flashing I should pull over. Can any suggest a fix for the light prior to handing...
try a simple diy job of replaceing the lambda probe (in between the exhaust manifold and the first box on the exhaust pipe).a quickfit type exhaust centre will do it in mins..
May 13, 2010 | GMC G1500 Cars & Trucks
Batory keeps dying over night in my vauxhall caverler sri mark 2
sounds like a earth fault, or have you changed the stereo? sometimes the power leads get mixed up. can be difficult to trace sometimes
Oct 15, 2008 | 1989 Ford Escort
Astra Home Grinder Electric Logo
27 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
