Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Reset drum continued...
Hi Tryit,
I tried it. I think I understand everything, but it was very tricky getting the cover off. I practiced on an old one. The small gear that matches up to the larger counter gear came loose, with two washers. Can you guide me in a technique so that doesn't happen? Can you tell me where the washers go? Is there a diagram or anything I can reference? And last, when the counter is properly rest, the 'flag' will be hanging straight down. Correct? Thank you!
  • 1 more comment
  • M Y Mar 28, 2008
    Ok, i'll do my best. With the counter reset, what are symptoms that the drum is really done and needs to be replaced. Will it make noise, stop copying, copy quality goes, etc.?
  • M Y Mar 31, 2008
    it worked and was easy. the gear that came loose when I opened the drum went back in place easily.
  • Anonymous May 03, 2008
    Can you be more specific about the flag location. I have a XD125f printer with the same error message. Thanks.
    President:
  • 2,072 Answers
The flag should be up. When it first turns on it will engage and move to the down position. It moves from top to bottom to swipe the reset. switch.
Since Xerox doesn't want anyone to know this. I can't find any pics of how it sets up.
Wish I did. That way when I do it I could remember exactly myself, It's pretty mush a hit and miss thing.
Posted on Mar 28, 2008
  • Rick Kasper Mar 31, 2008
    Good. It can be tricky to get done.
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
I have a xerox xc1044 Copier. I know the unit well. I have been able to fool the toner that there is not problem. The Drum light comes on. The drum looks good and I have opened and completely cleaned out...
When did you replaced the drum for the last time, or how old is the printer, optical insppection on the drum is not enough to say that there is no need to replace it.
Oct 26, 2008 | Xerox Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Dec 07, 2014 | Roland RMP-5 Rhythm Coach
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Phaser 8200 error message - lamps out
I was wondering if any of you have the guide with pictures on the instructions. I got to step 5 and I am stuck trying the remove the upper transport.
Thanks
nbt@tslnet.com
Jun 26, 2008 | Xerox Phaser 8200 Laser Printer
Drum symptoms?
Most likely you will start to get streaking. The cleaning blade will finally fail.
Mar 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
