Question about Nautilus Sport 5.18 LC Treadmill - Huge Savings & Free Silver Service Deliv
T518 keeps shutting off
Nautilus has sent new wiring for the display panel, new wiring from the display panel to the control board, a new power cord and a new control board and yet it still dies within 5 minutes. With all the back and forth with Nuatilus it has already been out of commision for 2 1/2 months. They seem to be just guessing. They even sent a new motor; however, it did not fit my machine. Any suggestions?
I found this posting on Amazon and it sounds very similar:
The internal circuit breaker would flip and the power would cut out.
The retail store sent out a repair guy and determined the transformer was overheating. They ordered a new controller board from Nautilus. Three weeks later the part finally arrived and the service guy installed it. After running on it for 5 minutes the same problem happened.
Hello. I'm actually the guy who posted the bad review on Amazon.com for this product.
Here's an update: The repair guy said over-lubrication MIGHT have been the problem. Since I had bought the machine I was lubricating per the schedule in the manual. The repair guy said that was too much and to only lubrciate every 200 miles or so.
After replacing the controller board AND the internal circuit breaker on the machine it worked OK... for another 5 months. Just tonight I was running on it and it shut down on me. Its the same symptom as before. The motor itself does not appear to be overheating (its cool to the touch). The controller board, however, is extremely hot right after it shuts down.
I called the retail store and they are going to call Nautilus to see what they should do. I do NOT recommend this model or even this manufacturer.
If anyone finds out the solution to this problem PLEASE post here.
Thanks!
Posted on Jul 07, 2010
    President:
  • Nautilus Master
  • 832 Answers
Did anyone address the issue of lubrication for the unit since the increase of friction will overheat components thus causing the unit to shut down.
Posted on May 10, 2010
  • John Mazmanian
    John Mazmanian Jul 12, 2010
    Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Dryer shuts off after one minute
  1. Lid Switch Doesn't Latch
    • A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
    Unsteady or Damaged Power Cord
    • A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
    Triggered Thermal Fuse Faulty Control Panel
    • The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
Dec 11, 2013 | Dryers
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Nstar shut off my power to fix something my washer was on. Now it is not working
Hello iamtubin2 - Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 09, 2012 | Frigidaire ATF6000ES Front Load Washer
The digital display keeps flashing and wont work
see this causes and fix it. God bless you
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
see the diagram attached and troubleshooting too.
Sep 30, 2012 | Washing Machines
Dishwasher wont run. i replaced the control board, still no power to board. i checked the power cord for electrical, and there is power to the cord. any suggestions?
having replaced the board and no power it. To me it seems like maybe a wire in between the inner/outer door panel may be broke. Check the area where the wires come from under the tub and enter the arae between the door panels and see if over time from a wire rubbing during the opening/closing of the door if a wire broke. Espically check the black wire from the house power connection into the control board
Aug 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Error code F11
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
  • Loose wire connection at either the machine control board or motor control board.
  • Machine control board failure
  • Motor control board failure
  • Door lock
  • Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  1. Unplug or turn the circuit breaker off for 10-20 minutes.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  3. Press the Pause/Cancel/Stop button twice to clear the display.
  4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'm receiving an error code CE on my Hayward H series 250 propane pool heater which is a communication error between the ignition board and the display board
Open up the control panel access door on the front. (the display). Remove the 2 screws at the top and tilt the assembly out. There should be a tab on the bottom that helps keep the assembly stable. Check all the connections on both boards for fit and broken wires. If all is ok, I would shut the supply power off, then back on and see if the data transfer works. If not, bad boards.
Jul 23, 2010 | Hayward H Series Electronic Ignition...
Display does not light up
This is problem many of hp cp1700 printers. LCD display have manufacter issuse. After some time degrage material joins LCD with controler. You can partial fix this issue, but you must take to parts front panel and repair cable contact on both side of plastic flat wire
(one side plastic flat wire and LCD, two side plastic flat and LCD controler board ). Repair must be done with stress dull tip and hot temperature, may use tinfioil and soldering iron.
OR you can bay new part panel board with lcd aproximaly 150$.
OR you do not repair printer and use pc program that view display info form printer display on pc monitor. On Linux I use HPLIP Toolbox.
Dec 03, 2009 | HP cp1700 Color Inkjet Printer
My Kenmore 9114742592 Wall Oven does not work. The display is blank and the circuit breaker is not tripped. What can I check for?
HI, check the junction box for separated power cord wires. replace the junction point if the wires are separated and not connected to the oven properly. replace the cord as well in this case.
Now, if the power cord is ok and, the junction is connected properly, this will confirm that the control or, clock has failed. replace the clock or, oven control board in this case.
Jul 10, 2009 | Kenmore Ovens
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Nautilus Sport 5.18 LC Treadmill - Huge Savings & Free Silver Service Deliv Logo
238 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
