Question about Philips 42FD9954 42 in. Plasma HDTV
Power Supply unit on Samsung 4253X
I'm trying to locate a store that could sell me the power supply unit for my 42" Samsung Model HPS 4253X, but no one sees to be able to help me without the part # which I can not locate
  • 2,337 Answers
Check this site for the power supply.
Posted on Mar 28, 2008
SOURCE:
Need power board for this model hps6373x/XAA
Fixya doesn't sell ANYTHING!!!...but SOME of its people will help locating the part needed, but others only say "fixya doesn't sell parts" instead of actually helping out.
Below is a link for a board for your TV.
SAMSUNG 63 PPM63H3QX XAA BN96 01411A Power Supply Board Unit
Feb 25, 2018 | Televison & Video
On/off switch Samsung 42'' Model 530 LCD
probably caused by the power supply board beginning to fail. eventually it will not come on at all.can call 1-800-samsung for nearest service center.VERY common problem.
Dec 30, 2009 | Televison & Video
Gateway 42 inch plasma p42m303 6 blinks on power supply
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Samsung 42 inches not turning on?
hi..the reason to this problem is the power
supply.check whether there is any power
coming from the supply unit.
check it out..
thank u..
Feb 13, 2009 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
Dell w4201chd 42" Plasma Tv.
OK, you need to replace the Power Supply Board.It is made by Samsung the number on the board will be LJ44-00110A. The Replacement number is LJ44-00019A,the cost is $349.00,however this part also crosses to a Phillips number 99500042146 which sells for $289.00 these are all the same board.I use the Phillips Board.Most repair shops will not do any research to locate these boards due to time and volume of repairs the have to deal with.Most call Dell and they won't give out repair info.They require it to be sent in.The Phillips board can be purchased from any NAP distributor.
Feb 11, 2009 | Dell W4201C 42 in. Plasma HDTV
Spn4235 42" Samsung Plasma 6 years old
you can get the power supply and/or the service manual (with schematics included) here.
http://www.samsungparts.com/search/search.asp
May 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung Plasma SPN4235 No Picture/But Sound
POWER SUPPLY IS WORKING IF YOU HAVE SOUND..WHEN Y-SUS GOES BAD..IF PUTS HEAVY LOAD ON POWER SUPPLY...WHEN YOU TRY TO POWER UP UNIT..IT WILL GO TO IMMEADIATE SHUTDOWN...THIS IS NOT THE CASE HERE..YOU SAID YOU HAVE SOUND...SOUNDS LIKE A BAD Z-SUS BOARD PROBLEM TO ME..CALL ANDREWS ELECTRONICS IN CALIFORNIA FOR PART # AND PRICE..JUST GIVE MODEL #...JOE ACE
May 16, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HPS 5073
If you have a complete shut down, How do you turn the set back on? Do you have to wait? Do you have to unplug the Set? In most case you may have a bad Power supply board. Part Number
BN96-01805A. Average Cost $60
Best regards
CircuitCity
Dec 01, 2007 | Samsung PS42P2S 42 in. Plasma Television
Philips 42FD9954 42 in. Plasma HDTV Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
