Question about Canon Office Equipment & Supplies
Canon MX308 won't print color images in grayscale with Windows 7. I only use a black cartridge in my printer. With XP it would print color images in grayscale, but after buying a Windows 7 laptop and downloading new drivers it won't print the color images at all. I have selected grayscale and have tried changing the color settings but it doesn't seem to work. It prints black text no problem. Solutions?
jackboy
  • 2985 Answers
SOURCE: Can I go to grayscale all the time?
Usually 'black' or greyscale uses all colours to get a true black in many printers. Check you particular printer manual and soft ware to see if it allows for black/grey only. You could experiment [I don't know this particular printer] by putting black carts in all slots [If it is a chipped cart you may have to consider swapping the chips on the carts if removable. Some specialist ink firms[Lycos] do supply monochrome sets for certain printers - check them out. Also take a look at www.fixyourownprinter.com
Posted on May 19, 2007
  • 238 Answers
SOURCE: computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Posted on Dec 17, 2007
Corysf62
  • 188 Answers
SOURCE: Won't print dark black; prints in gray
There are a few possible causes for the light print.
The first is the easiest to try and least expensive.
If you actually had a bad toner cartridge, and the toner was not making its way down the toner tube to the developer, then you may be able to fix the issue by simply doing a developer cleaning on the black developer. What this actually does is force aggitator to move toner down the tube into the developer. You can activate this from the maintenance menu.
If this does not fix the issue, then more then likely the black developer unit itself is defective and needs to be replaced.
Posted on Nov 13, 2008
ikechinedu
  • 184 Answers
SOURCE: Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Posted on Jun 09, 2009
komguy
  • 2306 Answers
SOURCE: I would like to print black with one color cartridge empty
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
Posted on Jul 20, 2009
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Using the Pixma mp800, running from windows 7, when I try to print in black and white photographs, the printer adds greens. How do I correct this?
your printer makes black from cyan, magenta and yellow when you tell it to prin black and white photographs. In the Printer Preferences you will find an option that is called: Print in High Resolution Grayscale using only the black cartridge.
If you check this function your printer will print only black and white with grayscale and will not use the color cartridge.
Jun 06, 2011 | Office Equipment & Supplies
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Describe how to change printer to print only black from my computer. I am out of color ink and don't know how to change the settings from my computer.
Unfortunately, you need both ink cartridges to print with this printer.
you can print grayscale (black/white) by:
This for XP:
Start
Settings
Printers and faxes
Right click the printer icon an select printer preferences
Click the color tab and select grayscale
Windows 7:
Start
Devices and Printers
Select printer preferences
Select features tab
Scroll down and add a dot to grayscale
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 18, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Im trying to print a picture in color. I click print and such and it will only print in black and white. I have a full ink cartridge, i have cleaned the dust off off the circuit board for the ink...
It can be that your printer is set to print in grayscale mode. To check this (depending on the OS) follow these simple steps.
If you have Windows XP.
go to the Printers and Faxes under Control Panel. locate your printer and right click it, then choose Printing Preferences. now depending on your printer, you should be able to find and uncheck the option to print in grayscale.
If you have Windows 7.
Go to the Devices and Printers and follow the rest of the instructions.
Hope this resolves your concern. Good luck.
Apr 14, 2011 | Computers & Internet
I have a canon mx310 color printer, I would like to disable the color ink cartridge as it is running low on ink
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/ Me/98 (if applicable)
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Dec 04, 2010 | Canon MX310 Office All-In-One Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Can't print in color on my Canon printer
If you go here you can download or view a manual for your printer, with detailed instructions on changing the print cartridge settings in windows or mac.
If you go here, you'll be taken to the home support page for your printer, where you can enter a search for "print in color", and detailed instructions will follow.
You go to control panel>printers>print preferences> and uncheck the grayscale printing and set the color to auto.
Issue: Image prints black and white instead of color....See below.
Solution: Uncheck Grayscale Printing checkbox (Windows)
Unchecking Grayscale Printing Follow the steps below to change the Grayscale Printing option:
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
    For Windows Vista: Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark.
  4. Click the 'OK' button to save the setting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
98 people viewed this question
old marine
old marine
