Question about GPS
Hi I have a boat GPS older model NS45 GPS fishfinder shows reciver not picking up all wireing is ok and has been fine for years. Has sat unused for 6 months we have changed battery in reciever but still not picking up ?? Regards Greg
  • greg417 May 10, 2010
    Have done the obviouse cleaned and checked corrosion
    Hi have checked all those things still no go
  • 16,181 Answers
ARe you sure of the model? I dont see anything on that.
What kind of battery does it take? Dont rate this answer please
Posted on May 10, 2010
  • 12,061 Answers
Hi, you see when any set, or unit is left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, as the moisture, is usually driven out, by the heat of operation, not to mention, any other sort of corrosion, or perhaps also, flat cells, batteries, in a unit, also inductors etc. So as said, this makes a unit more or less unrepairable. if you are not lucky. You will have to get this looked at by a professional, in my professional opinion, I think you need to contact, the manufacturers website, and ask about repair, then send it for repair, BUT ask for a "Quote" for the repair before proceeding, that way, you can make an informed decision,as to repair or replace. As these days often, things can cost almost as much, if not more, that a new unit, with a warranty..
    Guru:
  • 312 Answers
If it has set for 6 months I suggest you take out the battery and be sure all connecting points are clean and free of any corrosion. Corrosion will occur quite rapidly from a dead battery. Clean your receiver very good too because if it was working prior to the 6 months it could be corrosion. Also I would check the new battery to be sure it is fully charged and producing power. Darrell S
  • Darrell Sorenson May 10, 2010
    A last resort is to get on google and google for the manufacturer. Then surf around in their web site looking for parts and service. Also ask for a manual. Most manufacturers have a list of local parts and repair shops authorized to work on their products. I would try that. Also ask about warranties if they have had problems with this same equipment in the past they may give you a new one or credit on a new one. Good Luck Darrell S
No transducer
Make sure the plug that gives this unit power is secure. Also I think this device has a 2ft branch that goes to the ducer. Make sure that's right too
Apr 10, 2014 | Garmin FishFinder 240 with Transom Mount...
Lowrance hds 5
I would imagine it might have something to do with water turbulance? Do you have a sensor thats located at the bottom of the boat somewhere? In my grandpas boat, the sensor is at the rear bottom near the hole where you can drain the water, if your going very fast it doesnt work very well, slow or stopped and it works fine. If you have that type of sensor make sure whatever holds it is tight so the sensor cant move around.
either that or you got some funky wiring issue lol
Nov 01, 2013 | Lowrance Hds-5 GPS Receiver
Gps problem
If the new harness / parts are listed for use with this model GPS, it should work - unless you have miswired something. Double-check your work. Make sure all connections are made up tight. Pay particular attention to the ground wire. Relying on the boat to pass ground it not reliable. Look for damaged or cut cable from power source and transducer. You may wish to troubleshoot with a meter or a test light to be sure power is available at the GPS. Good luck!
May 29, 2013 | Humminbird 1198C SI Side Imaging High...
Hello, my Humminbird 565 startred to misread the tempereture, when stoped or in low speed it show the water temp 10º c bellow the real temp. The same happens in Fº. The sounder otherwie works...
More than likely you have your sensor run underneath the boat and therefore the sensor is directly in the water. When you speed around the hot water on top is what your sensor is picking up, when you slow, you are allowing the sensor to pick up on the colder water just inches below the surface
Jun 03, 2010 | Humminbird Fishfinder 565 With Transom...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Wont search for sattelites
Hi
Does your unit have an external aerial as shown in the pic, If so double check the connection from the aerial into back of the fishfinder, lube with water proof grease (Non-conductive)
You do not say whether it has worked before.
Also need to know where it is located on boat, it must have a view of sky overhead (If internal antennae)
Ext antennae must also be in view of sky, not under "solid" cover.
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
Convert portable batteries to 12 volt boat ststem, Eagle Super Pro I.D
Cut the battery wires where they hook up to the machine. When cut they might need some more wire spliced to them. Get some alligator clips to put on your red and black wires to hook right to your boat battery. When not in use on the boat get a small 12 volt battery, cheaper then two 6 volt disposables.
Aug 10, 2009 | Eagle Fishmark 320 Portable Fishfinder
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
Garmin gps 498.
I think the transducer is down too low. Raise it up so that the center of it is in line with the bottom of the boat.
Jun 02, 2009 | Garmin GPSMAP 498 Fishfinder /...
Repeated transponder issues with the lowrance 320c fishfinder
Reading the manual it does say that there is a temperature range for these. I"m not sure where you live but it might be cold enough that it is damaging the transducer in the off winter months.
Jun 01, 2009 | Eagle Fisheasy 320c Fishfinder
GPS Logo
19 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
