Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Saw will start and run about 20sec. till you push the choke in and then stop like it run out of gas ,replaced the fuel line and filter , put a kit in carb. adjusting the h & l screws makes no difference could it be crank seals?
    Brigadier General:
  • 4,088 Answers
Go to: http://www.drystacked.com for a 12 page PDF document on Walbro carburetors. Pay special attention to the caution about the lower chamber gasket and the diaphragm. Crankshaft seals rarely become a problem until the crankshaft main bearings have worn so much that the crank shaft can be visibly moved sideways. Make sure the muffler and air cleaner are not plugged. A basic setting for H and L jet screws is turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. The engine should start and run with these settings. Allow the engine to warm up, then open the throttle and adjust H CW until the engine starts to speed up but continue 4-stroking. Proper final adjustment is 4-stroking, but immediately 2-strokes when cutting. Let idle and adjust L CW until engine runs fairly well, but will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps.
Posted on May 10, 2010
I have a poulin pro 220 chainsaw. I just replaced the primerbulb and the only way it stays running is if the choke is fully on. If you put the choke to half or off it runs for a few seconds then dies
Check and see if the fuel line is collapsing when you start. The wonderful gas that we have contains alcohol which deteriorates rubber. Gas lines and many carburetor parts are eaten up by this gas. When you go to start your saw it has enough to run but the suction from the carburetor collapses the fuel line, weakened from the alcohol, not allowing any more fuel to pass. When the suction stops, when the saw shut off, the fuel opens up again allowing you to start it again. I had this problem when the government forced this crappy gas on us in the late eighties and I had to carry extra spare parts for my saws because of these problems. Anyways enough ranting, try and change the fuel line and that would most likely be your problem. If it is an old saw it might have done damage to your carburetor and it will need a carburetor kit/rebuild which is not usually too expensive. Hope this helped.
Sep 28, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Chain saw stars good w/choke but won't run
Replace the fuel filter in the tank, if there is any sign of leaksge on the fuel hose replace this as well
Sep 02, 2012 | Garden
I have a McCulloch MS1636NAV chain saw. The engine starts with the choke pulled out. When I push the choke in the saw dies. I've changed the spark plug, replaced the air filter. changed the gas, 40:1.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Oct 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Starts but dies when warmed up or gas it and choke off dose this couple times then wont start till totaly cold again
Check the fuel filter, air filter, and muffler for plugging. Inspect the fuel lines for decay or damage. Make sure the carburetor fasteners are tight including the carburetor to cylinder mountings. If still not running properly, service the carburetor and rekit if the diaphragm in the lower chamber is hard or cracked. Also, inspect the fuel metering valve that the diaphragm controls. If the tip of the needle is damaged, replace it. Remove the spark plug and check for snappy, blue spark when the saw will not start. Hope this helps!
Jun 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan PP446T Pole Saw. Will run only if choke is fully closed. Open the choke and it stalls. Have replaced the fuel filter, cleaned carb, installed carb kit. Cleaned gas lines. Good gas mixture(other saw...
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Jan 22, 2010 | Poulan Garden
Poulan chain saw mod. SM4018 Hard to start & won't accelerate
Your carburetor needs cleaned. It may also need a carburetor kit, depending on how old or how long it has been since service. While you have it apart, you may as well clean or replace the air filter and check fuel lines for cracks or brittleness. If you need tips on how to clean carb. or changing fuel lines, just let me know.
Jim
May 30, 2009 | Poulan Garden
Starts with choke but dies
if you reach down inside the fuel tank with a wire and pull out te fuel line there should be a fuel filter on the end of that. replace the fuel filter and you should be good to go.
Mar 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
168 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
