Question about Garden
I cant get my lawn mower to start i dont know
I have tryed everything possible and does not want to start
when i take the plug of it comes out wet all the time.i get it dry with a cloth and i squirtted a bit of petrol in the plug hole;it starts for about 10 secounds and turns it self off i dont know why.can any onehelp please
    Sniper:
  • 53 Answers
Sounds like you are flooding it. here try this. go to your mower, prime it by pushing the bulb 3 to 5 times, set the choke, pull it once, maybe twice. If it don't start leave it alone 15 minutes (ON THE CLOCK) then come back take the choke of (set it to "run") and try pulling one more time. See if it starts when you pour gas in, its working, OHHHH Hooo! It just hit me! Is the gas in the tank 100% fresh? I don't mean mixed with a little old gas and hope. MUST BE 100% Fresh. See the contradiction here is wet plug no start, (You are obviously getting the gas) But you pour in the gas and it starts? I bet if you poured in the gas its more than 1 pull would give it from the tank! You see what I'm getting at? That tells me you may have bad gas vs. fresh gas!
Posted on May 10, 2010
  • Ed Gore May 10, 2010
    Let me know what happens. (sorry if reading the first post is confusing you a bit. I saw the typographical errors and could not re-edit them out) ie: See if it starts? I mean, when "YOU" pour gas in its working! What I really mean is, you pouring in the gas thru the spark plug hole would flood it more than 1 or 2 pulls would. But...it ran right? So why doesn't it run when its wet with the gas from the tank when you try to pull it to start? If the gas in the tank is fresh 100% then you are giving it too much throttle too soon and flooding it out. Use the choke, back off on the throttle, and last EZ fix is....STARTING FLUID! (great stuff that is! Could win a war with it in the right places!)
Electric lawn mower has bad fault in the power switch
take it to a mower shop that has an electrical ticket or an appliance shop for repairs
wet grass , makes a good conductor for diy failures unless it is a 18-24 volt battery unit
Jul 21, 2016 | Electric Garden
How do I get my Tecumesh Model H35-45430M lawn mower motor running. Have cleaned, soaked it in solvent that would take the hair off a mouse as well as trying with the choke full on which does not wet
You can over soak it and if you soak it in any strong solvent that does not affect gasoline solvent you have wasted your time. You should never need to remove welch plugs. With more information someone might be able to better advise you. Pull the plug and with an oil can or the like squirt a small amount of fuel into the cylinder and then screw the plug back in and see if it will start and run.
Nov 24, 2014 | Garden
Lawn Boy Gold Series self propelled 5.0I want to know what keeps spelling out the spark plug I run it for a little bit and then turn off and come back a couple hours later and it wont start spark plug is...
"I run it for a little bit and then turn off and come back a couple hours later and it wont start spark plug is wet"
From this little bit of info it sounds like the carburetor float needle seat is leaking and is filling the cylinder with fuel. A good cleaning and rebuild of the carburetor will probably resolve the problem and is where I would start if it was in my shop.
Without the actual model number I wasn't able to get any further info,
Nov 05, 2014 | Garden
What could be the problem if my lawn mower won't start?
ck to see if you have spark to the plug if not the coil mite be bad,,And ck to see if plug is wet ,,,if plug is wet get a new plug,,,,first,,,see if that works! if not then wright back
Oct 08, 2014 | Craftsman Garden
Corded electric mower loses power then comes back on during use
Same likely answer from several possibilities. Likely to be a poor electrical contact. Check *the supply had good contact for plug and an adequate fuse. *possible loose contact in the handle switch *if several years old, possible worn carbon brushes in motor. Easy to replace. *You should be using an RCD cut out switch. Check if mower works without it. Replace if dodgy
NB Only try to fix last two if you know what you are doing!
Aug 21, 2013 | Electric Lawn Mower
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
Am having a hard time trying to start my lawn mower
Remove the spark plug, Make sure it is clean, then before putting it back in, wet the tip with clean freshfuel. Chk and clean the air filter. Make sure any shutoff on any remote controls on the handle is in the run position. Good Luck
May 28, 2010 | Craftsman 19 in Premium Battery Powered...
I have a toro recycler lawn mower that was made in 2005 according to the sn. it wont start. we have tore it down to check everything but still nothing. It has spark. after pulling a few times we check the...
If you have spark and gas, it should start. The plug shouldn't be wet with gas, adjust the carbuerator fuel flow screw to reduce fuel to the engine. Use full choke to get it started
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
