Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Can't find my instructions. How do you turn on the tools part of the vac? Thank you Meagan
    Brigadier General:
  • 7,191 Answers
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on May 10, 2010
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water isdischarging from the exhaust of my new Ridgid Wet/Dry Vac
Hi Robinm61,
I always have the filter in - - it helps protect the motor.
If you're going to vac liquids, I recommend use of an intermediate trap to stop most of the liquid from getting to my vac (makes clean-up a LOT easier). A cyclone-top (available at Rocker.com, for example) fitting on a 5-gallon pail works great. The liquid is mostly deposited in the 5-gal pail, and doesn't gum-up the guts of your vac. You need another section of hose, but that's another one of those tools that is hard to have too-much of. (Rockler also sells a nice hose as part of it's Vacuum Tool Kit - also at Rockler.com). Photos (courtesy of Rockler.com) follow below.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Dec 27, 2008 | Ridgid 25648 Wet/Dry Vacuum
Need help attaching vac hoses to shampoo couch.
Here are the instructions. But please be very careful and shampoo an inconspicuous area prior shampooing entire piece of the furniture.
Sep 27, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Using attachments...can't find my manual ; when using attachments the
hi in answer to your question regarding the belt driven roller/brush on bottom of vac ? the nswer is yes it still rotates when you are using the tools on connection to flex hose ie stair carpet or areas the vac will not enter one word of advice ! if you use the vac/tools to vac the car interior as i and others do ? then ensure that whilst vac is stood and the flex hose and tool are in use? suggest you stand the vac on a flat surface(not the tarmacdrive or any porouse surface) preferably a rubber mat? or board so the rollerbrush is not subject to damage or apt to pick up stone chips etc which will eventually damage the motor impellor hope this helps answer your question and understand the safety point i mentioned best wishes
Oct 23, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
59 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
