Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca there is 2 wires that run along were the screen is they both meet up at the bottom of the screen and theres a clip on the clip there is a sticker that says j conv senes and theres is nothing attached to it.
    Genius:
  • 1,030 Answers
These are you convergence sensor wires.....why they disconnected? has the screen been remove... what this will do is disable autoconvergence sensors...there should be along two wire bundle that runs under the screen behind the screen through past the lens into the back right in the middle into a bundle of wire. the plug should be there somewhere.. look around for it
Posted on Mar 28, 2008
Have a frigidaire dryer older model wires came off timer M460G. Has A-B-C on top and on bottom it has a TM-X-R. Please anyone help me?
Normally on a older Frigidaire dryer the wiring diagram is located under the top. There are two clips located about 2-3 inches from the left and right side of the top panel where it meet the front panel. Use a putty knife push the clips in and raise the top. The wiring diagram is under the top hope this helps.
Oct 18, 2014 | Dryers
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
My top screen is separated from my bottom screen but it still works because a part from the right hinge broke off. The only problem is that my microphone doesn't work. How can I fix it?
There are 2 thin wires that run along the inside of the spine that clip onto two connectors on the mother board - one is the microphone. It sounds like this has become dislodged. Unscrew the back and check if one of the two wires is loose. On YouTube there is a great tutorial for "how to repair Nintendo DS Lite touch screen by supermodchips that explains very clearly where this wire should be. Good luck
Dec 27, 2010 | Nintendo DS Lite Console
Model# 110.74994301. How do you remove front bottom panel from dryer
Just insert a putty knife along the top seam where the bottom panel meets the dryer front, about two inches in from each side. There is a retaining clip that you need to slide the putty knife into to while pulling out slightly on the bottom panel to release.
If you have any questions, please post back and let me know. I hope this helps you.
May 08, 2010 | Dryers
WHICH CABLES ARE BEST FOR THIS AMP MY MIXER HAS RCA CABLES TO 1/4 PLUG SOUNDS CRAPPY
The RCA output from your mixer is an unbalanced source, and will pick up electromagnetic noise from the environment along with your signal. You can minimize this by running the mixer as loud as you can without clipping, so the amp doesn't have to be turned up as much.
Ultimately though, you'll want to get a sound source (from your current mixer or from a new mixer) that can run balanced wiring to the amp.
Sweetwater has a decent tech tip spread out over two days (day 1 and day 2)
There's also a decent wiki on the topic.
And here's a good page with great content and good graphics, all on a completely horrible yellow background. Good luck!
Be sure to hit the thumbs-up if this helps, and post a comment back if you've got questions!
Nov 03, 2009 | Marathon DJ-2000 Amplifier
Gateway 7330GZ PC Notebook screen going off and on
Ya, my 7330GZ has been having this problem. I did end up taking the screen apart.
Removing the little black nubs around the screen allow you to remove the screws, then you just use a flat headed screw driver to unclip around the edges (some can be stubborn, especially along the bottom).
The screen is glued to the casing along the top and bottom, so you have to gently separate the two.
After you have it opened up the screen has 3-4 screws along the left and right side (the right side is a pain to unscrew since the wireless antenna casing runs right along it).
Once you remove those screws you can take the screen out and get access to the ribbon cable running along the back.
Aug 11, 2008 | Gateway 7330GZ Notebook
KitchenAid Washer
My best guess would be you have a bad motor coupler(a hybrid plastic/ rubber gear that acts as part gear, part shock absorber). Unless you lift the lid, it would sound like it is doing a normal wash and spin. The water still fills, the motor still runs, etc. To verify this, first unplug your washer. Pull it forward slightly and tilt it back about 6". Use a flash light to show you the underneath side. You will likely see black shavings, pieces of white plastic, or possibly even a mangled chunk of black rubber. This is what is left of your coupler. If you are able to verify this, grab your model number. Just lift the lid and look towards the rear where the lid and top of the unit meet. In the center where they meet you should see a plaque with your model number in it. Once you have your replacement coupler, here's how you replace it. 1st - Unplug the unit. Next, open your console. The most common ways to do this are either 2 phillips screws on the back of the console where it meets the top of the washer on the right and left hand sides or there are 2 cosmetic caps on the front of the console. Once you remove the caps, you will find 2 phillips screws to remove. Once the screws are out, pull the bottom of
the console towards the front and swing it up. (it should be hinged). Underneath, you fill find 2 large brass colored clips. Find the area where the clips go into the top of of the unit. Use a large screwdriver to simultaniously push down and push the handle
towards the back of the unit. This will let the clips out. Now, open the lid and grab the opening for the clothes and pull it towards you while placing your foot at the bottom center to keep it in place. Once you reach about 45 degrees forward, let both the bottom and the top come forward slowly at the same time. Now with the cabinet out of the way, look towards the bottom center of the machine. You should see a white piece of plastic
with two black hoses connected. That is your pump. Pry off the two clips holding it on. Underneath is your motor. On the right hand side there is a wire harness. Follow the 2 red wires. This is your capaicitor. If you touch the metal parts is can kill you. So,
pull the wires off, then touch a large screwdriver across the two metal plugs where the wires just were. It is now safe. Unplug the rest of the wires where they connect to the motor. There are 2 more clips keeping the motor in place. First remove the screws (they will be either 5/16 or 1/4" screws). Then again pry the clips off. There is a shaft on the back of the motor and a matching shaft behind it on the transmission. Remove any remaining coupler pieces. (you may have to pry or break off the remianing pieces) Take the new parts and press them on the shafts (I find using a spark plug socket and a hammer to press it on works best). Now re-assemble in reverse. If you didn't have the shavings or run in to any other problems, drop me a comment and we can keep working off this request for help. If it took care of it, please make sure to post a rating for this information. I look forward to hearing from you.
Jul 21, 2008 | KitchenAid KAWS850L Top Load Washer
Roper washer wont spin or agitate.
It sounds like you have a broken coupler. (a hybrid plastic/ rubber gear that acts as part gear, part shock absorber). To verify this, first unplug your washer. Pull it forward slightly and tilt it back about 6". Use a flash light to show you the underneath side. You will likely see black shavings, peices of white plastic, or possibly even a mangled chunk of black rubber. This is what is left of your coupler. If ou are able to verify this, grab your model number( the one supplied [ras6223kq] does not come up aa a vailid number). Just lift the lid and look towards the rear where the lid and top of the unit meet. In the center where they meet you should see a plaque with your model number in it. Once you have your replacement coupler, here's how you replace it. 1st - Unplug the unit. Next, open your console. The most common ways to do this are either 2 phillips screws on the back of the console where it meets the top of the washer on the right and left hand sides or there are 2 cosmetic caps on the front of the console. Once you remove the caps, you will find 2 phillips screws to remove. Once the screws are out, pull the bottom of the console towards the front and swing it up. (it should be hinged). Underneath, you fill find 2 large brass colored clips. Find the area where the clips go into the top of of the unit. Use a large screwdriver to simultaniously push down and push the handle towards the back of the unit. This will let the clips out. Now, open the lid and grab the opening for the clothes and pull it towards you while placing your foot at the bottom center to keep it in place. Once you reach about 45 degrees forward, let both the bottom and the top come forward slowly at the same time. Now with the cabinet out of the way, look towards the bottom center of the machine. You should see a white piece of plastic with two black hoses connected. That is your pump. Pry off the two clips holding it on. Underneath is your motor. On the right hand side there is a wire harness. Follow the 2 red wires. This is your capaicitor. If you touch the metal parts is can kill you. So, pull the wires off, then touch a large screwdriver across the two metal plugs where the wires just were. It is now safe. Unplug the rest of the wires where they connect to the motor. There are 2 more clips keeping the motor in place. First remove the screws (they will be either 5/16 or 1/4" screws). Then again pry the clips off. There is a shaft on the back of the motor and a matching shaft behind it on the transmission. Remove any remaining coupler pieces. (you may have to pry or break off the remianing pieces) Take the new parts and press them on the shafts (I find using a spark plug socket and a hammer to press it on works best). Now re-assemble in reverse. If you didn't have the shavings or run in to any other problems, drop me a note back.
Jul 08, 2008 | Roper RAS6233KQ Top Load Washer
RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Apr 13, 2008 | RCA P52937 52" Rear Projection Television
Projection tv
chirrping.....is indication of shutdown issue first thing to chech is make sure that the flat ribbion cables foint from the green board over to the power board are in place...this set shuts down for many reasons.. the most likely in your case would probalbkly be a blown horizontal output transistor. which could also mean a blown flyback transformer. a technician can replace these ..typical repair cost is about 100 to 300 dollars.
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
