Question about Ovens
My kitchenaide superba oven fan is LOUD, oven works but it is so noisy, what is causing this?
  • cellino May 10, 2010
    Thank you! Yes the oven is less than 3 years old, I will look up the number to give them a call. Thanks
    President:
  • Ovens Master
  • 2,923 Answers
This is a common issue with Kitchenaide Superba ovens. What is the model number of your oven and how old is it?
The common cause of the loud noise is that the screw came loose and the noise you are hearing is a vibrating sound rather than a wobbling blower wheel.
Most Kitchenaide superba oven have 5 years warranty. I would suggest to contact the manufacturer if it's still under the warranty period, because the blower motor you have is mounted in a metal housing. And the manufacturer has an easier access to this potion. They need to replace or tighten the screws.
Thank you and good luck!
Posted on May 10, 2010
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Ovens Logo
170 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
