Power dead on Satellite M45-S351
I have a 1-1/2 year old Satellite M45 now 6 months out of warranty that has been virtually unused for the last 8-9 months. I was using it yesterday and installing Norton Partition Magic 8.05 on it to partition the 100 Gb hard drive. After installing the program from a USB flash drive the computer reboots. In this case it shut down and did not restart. It doesn't even have any power or signs of power, even with the AC adaptor plugged in. No LED's light up on the front, no lights on the power button. I have tried removing the battery and the AC and letting it sit, using just the AC, etc. It seems dead as a mackerel. Does anyone have any ideas out there? TIA forgot password to laptop
  • july121 Mar 28, 2008
    forgot password to satellite m45 s359
  • 26 Answers
If you forgot your password there is no way to get it unless you
take unit apart removed keyboard look for CMOS battery, if there is one on the unit take it out let unit stan d for 60 second, then put it back in, this sometime clear the cmos,, if all fail it may be your system board
Posted on Mar 28, 2008
6ya staff
SOURCE:
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
Hi, I re-installed the hard drive on this laptop (Toshiba Satellite M45-S169), but the hard drive is unresponsive. Not sure if I installed correctly, or the hard drive is dead. The power light comes on,...
If drive not spinning, definitely dead. If spins and not recognized by laptop cmos, the logic board on drive is toast.
Afraid that you have a nice cute paperweight.
Sep 03, 2017 | Toshiba Satellite M45-S169 Notebook
I only had about 30 hours on a Toshiba Satellite M45-S169 laptop when I put it in it's bag about 5 months ago. Recently got it out to use and have no power. Doesn't seem to be the power cord though as...
take out the battery. plug the AC adapter w/o the battery in. make sure the power outlet is working. you should see a light indcator. test if you can boot it up.
Hope this helps...
Sep 08, 2010 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
When I turn the computer on the screen doesn't work
This is the monitor not being attached to the Graphics Card properly.
Sep 14, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
DVD-CD Drive keeps opening itself
This is due to the motor fault..you have to take it to service center as it is under warranty..
Dec 30, 2008 | Toshiba Satellite M45-S2652 Notebook
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S351 BIOS password needs help!
BIOS passwords on Toshiba notebooks have to be reset by an authorized service technician who has the CD available to run the utility.  Their notebooks don't contain a battery reset to erase the password.  It was done as a safety feature to prevent theft from happening and it is a very good one.
If you take it into Best Buy or a computer dealer to get it done, you might have to prove that you are the new owner of the computer before it can happen.
Sep 23, 2008 | Toshiba Satellite M45-S351 Notebook
Dead Toshiba Satellite M45 S-169
hi dear
maybe you can try to check your memory module
release your memory module, use am eraser to cleaning your memory. and install it again
ok
Mar 23, 2008 | Toshiba Satellite M45-S169 Notebook
Open Questions:
Computers & Internet Logo
189 people viewed this question
Ekse
Marvin
Marvin
