Question about Maytag MED5800TW Electric Dryer
Dryer won't shut off automatically
Turned off wrinkle guard so that's not it.
    President:
  • 1,382 Answers
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
Posted on May 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite dryer - how do I turn on the wrinkle
Head over to the manufacture's website.
www.searspartsdirect.com
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
  • 56 Answers
SOURCE: How do I turn off the wrinkel guard?
youcant that i know of unless it gives you that opition on the console just turn off power when cycle is over
Posted on May 31, 2009
  • 43 Answers
SOURCE: My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Posted on Oct 16, 2009
SOURCE: how do I turn off
I see I am not the only owner who wants to this off!
Posted on Sep 01, 2011
Joe Onley
  • 363 Answers
SOURCE: How do you shut off
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
My dryer WED5820SWD wont stay running unless I hold in the start switch. It happened the other day in the middle of the cycle, also the wrinkle guard stoped working as well. I think that it is the timmer?
Sounds like you have a bad door switch, if it wont stay running and reason for the wrinkle guard not working is the electronic control (circut board) is bad.
Aug 05, 2010 | Whirlpool WED5800S Electric Dryer
Kenmore elite dryer - how do I turn on the wrinkle guard? if the light is steady - is that on? is the light for the wrinkle guard or the damp dry cycle. Why does the static guard light flash?
Apr 16, 2010 | Kenmore Elite HE4 Electric Dryer
Oct 16, 2009 | Dryers
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
May 30, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer continues to spin periodically after the clothes are dry - doesn't shut off completely
yvonne sorry but that isn't a feature you are able to turn off. It happens that the buzzer goes off as well that people don't like. Only the top of the line model allows the buzzer to be turned off. The wrinkle guard is just that, to help prevent wrinkles.
Jul 22, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Display
Check your manual. Sound like wrinkle guard setting
Nov 17, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MED5800TW Electric Dryer Logo
388 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
